Link to this comparison view
Next revision
Previous revision
indigo_5_documentation:folder_class [2011/04/13 02:28] – [Examples] jayindigo_5_documentation:folder_class [2024/06/27 00:08] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== Folders ======
 +The folder class represents a folder in the various Indigo user interfaces (Mac client, Indigo Touch, web, etc.).
 +==== Class Properties ====
 +^Property ^  Type  ^Description ^
 +|//''id''// integer  |the unique id of the folder, assigned on creation by IndigoServer|
 +|//''name''// string  |the name of the folder - no two folders in the same namespace (i.e. //''indigo.devices''//) can have the same name|
 +|//''remoteDisplay''// boolean  |should this folder be displayed in remote clients (IWS, Indigo Touch, etc)|
 +==== Commands (indigo.*.folder.*) ====
 +The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder.*, indigo.variables.folder.*, etc).
 +=== Create ===
 +Create a folder. This method returns a **copy** of the newly created folder.
 +^  Command Syntax Examples  ^
 +|<code>indigo.variables.folder.create("Folder Name Here")</code>|
 +^  Parameters  ^^^^
 +^  Parameter  ^  Required  ^  Type  ^  Description  ^
 +|//''name''// Yes  |  string  |the name of the folder|
 +=== Delete ===
 +Delete the specified folder.
 +|<code>indigo.devices.folder.delete(123, deleteAllChildren=True)</code>|
 +^  Parameters  ^^^^
 +|direct parameter|  Yes  |  integer  |id or instance of the folder to delete|
 +|//''deleteAllChildren''// No  |  boolean  |a boolean to specify whether all objects contained in the folder should be deleted as well - defaults to //''False''//|
 +=== Duplicate ===
 +Duplicate the specified folder. This method returns a copy of the new folder.
 +|<code>indigo.controlPages.folder.duplicate(123, duplicateName="New Name")</code>|
 +^  Parameters  ^^^^
 +|direct parameter|  Yes  |  integer  |id or instance of the folder to duplicate|
 +|//''duplicateName''// No  |  string  |name for the newly duplicated folder|
 +=== Set Remote Display ===
 +Use this command to set the remote display flag for the folder.
 +|<code>indigo.devices.folder.displayInRemoteUI(123, value=True)</code>|
 +|<code>indigo.schedules.folder.displayInRemoteUI(123, value=False)</code>|
 +^  Parameters  ^^^^
 +|direct parameter|  Yes  |  integer  |id or instance of the folder|
 +|//''value''// Yes  |  boolean  |True to display the folder on remote user interfaces or False to hide it|
 +==== Examples ====
 +Since folders aren't available in AppleScript, we're only providing Python examples here.
 +<code># create a new variable folder
 +newFolder = indigo.variables.folder.create("My New Variable Folder")
 +# test to see if a folder exists by Name
 +if ("My New Variable Folder" in indigo.variables.folders):
 +    # should execute this because we just created it
 +    indigo.server.log("folder named 'My New Variable Folder' exists")
 +# test to see if a folder exists by ID
 +if (newFolder.id in indigo.variables.folders):
 +    indigo.server.log("folder id " + newFolder.id + " exists")
 +# set the remote display flag on the folder immediately
 +indigo.variables.folder.displayInRemoteUI(newFolder, value=False)
 +# a ValueError exception with the text "NameNotUniqueError" is thrown if you try to
 +# create a folder with a name that already exists
 +try:
 +    indigo.variables.folder.create("My New Variable Folder")
 +except ValueError, e:
 +    if str(e) == "NameNotUniqueError":
 +        # should execute this because it's a dup name
 +        indigo.server.log("folder named 'My New Variable Folder' already exists")
 +    else:
 +        indigo.server.log("Some other error")
 +# NOTE - at this point, newFolder.remoteDisplay is still true (default for new folders)
 +# because we're still working with a copy. Refresh it to get it updated:
 +newFolder.refreshFromServer()
 +# change the name of a folder
 +newFolder.name="My Variable Folder"
 +newFolder.replaceOnServer()
 +# duplicate the folder
 +indigo.variables.folder.duplicate(newFolder, duplicateName="My Duplicate Folder")
 +# delete a folder
 +indigo.variables.folder.delete(newFolder)
 +#test to see if a folder doesn't exist using name
 +if ("My New Variable Folder" not in indigo.variables.folders):
 +    # should execute this because we just deleted it
 +    indigo.server.log("folder named 'My New Variable Folder' does not exist on the server")
 +# test to see if a folder doesn't exist using ID (was deleted perhaps)
 +if (newFolder.id not in indigo.variables.folders):
 +    indigo.server.log("folder id " + newFolder.id + " does not exist on the server")
 +</code>
