| Both sides previous revision Previous revision | |||
| indigo_6_documentation:advanced_powerlinc_options [2012/10/18 21:44] – jay | indigo_6_documentation:advanced_powerlinc_options [2025/04/14 20:10] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Advanced PowerLinc Options ====== | ||
| + | Indigo provides some advanced options for the various PowerLinc INSTEON interfaces. Select **'' | ||
| + | The first two options should always be checked by default - you really only want to disable those options if the Indigo Support team recommends it. | ||
| + | From this dialog, you can also perform some other link syncing operations: | ||
| + | * Start/Stop Link Sync (same as using the menu items on the **'' | ||
| + | * On your PowerLinc, you can clear all its internal links, read all the links, and sync links. You normally won't use these options unless instructed by Indigo Support | ||
| + | * You can completely reset your PowerLinc and resync the links all in one go - this is roughly synonymous to doing a factory reset, but not quite. Indigo support will often recommend doing a factory reset vs using this option because the factory reset performs some actions that we can't do through software. | ||
