| Both sides previous revision Previous revision | |
| indigo_7.3_documentation:insteon_specific_commands [2019/04/05 21:10] – [Send Scene Start Change] jay | indigo_7.3_documentation:insteon_specific_commands [2025/04/14 20:10] (current) – external edit 127.0.0.1 |
| | ====== INSTEON Commands (indigo.insteon.*) ====== |
| | Commands that are specific to INSTEON devices. |
| | ==== Send Scene Decrease ==== |
| | This command will send an INSTEON Scene Decrease (dim on dimmable loads) command to the specified PowerLinc scene. The value will decrease by 3% for each call. |
| | ^ Command Syntax Examples ^ |
| | |<code>indigo.insteon.sendSceneDecrease(11)</code>| |
| | |<code>indigo.insteon.sendSceneDecrease(11, repeatCount=5)</code>| |
| | |<code>indigo.insteon.sendSceneDecrease(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneDecrease(11, updateStatesOnly=True)</code>| |
| | |<code>indigo.insteon.sendSceneDecrease("working in office scene")</code>| |
| | ^ Parameters ^^^^ |
| | ^ Parameter ^ Required ^ Type ^ Description ^ |
| | |direct parameter| Yes | integer or string |either the scene number or the scene name - we encourage numbers since they won't change and the scene names can.| |
| | |//''repeatCount''//| No | integer |a value from 1-32 for the number of times to repeat the decrease (default is 1)| |
| | |//''suppressLogging''//| No | boolean |True if entries in the event log should be suppressed (default is False)| |
| | |//''updateStatesOnly''//| No | boolean |use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False)| |
| | ==== Send Scene Increase ==== |
| | This command will send an INSTEON Scene Increase (brighten on dimmable loads) command to the specified PowerLinc scene. The value will increase by 3% for each call. |
| | |<code>indigo.insteon.sendSceneIncrease(11)</code>| |
| | |<code>indigo.insteon.sendSceneIncrease(11, repeatCount=5)</code>| |
| | |<code>indigo.insteon.sendSceneIncrease(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneIncrease("working in office scene")</code>| |
| | ^ Parameters ^^^^ |
| | |//''repeatCount''//| No | integer |a value from 1-32 for the number of times to repeat the increase (default is 1)| |
| | ==== Send Scene ON ==== |
| | This command will send an INSTEON Scene ON command using the specified PowerLinc scene. |
| | |<code>indigo.insteon.sendSceneOn(11)</code>| |
| | |<code>indigo.insteon.sendSceneOn(11, sendCleanUps=False)</code>| |
| | |<code>indigo.insteon.sendSceneOn(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneOn(11, updateStatesOnly=True)</code>| |
| | |<code>indigo.insteon.sendSceneOn("working in office scene")</code>| |
| | |<code>indigo.insteon.sendSceneOn("working in office scene", sendCleanUps=False)</code>| |
| | ^ Parameters ^^^^ |
| | |//''sendCleanUps''//| No | boolean |True if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)| |
| | ==== Send Scene OFF ==== |
| | This command will send an INSTEON Scene OFF command using the specified PowerLinc scene. |
| | |<code>indigo.insteon.sendSceneOff(11)</code>| |
| | |<code>indigo.insteon.sendSceneOff(11, sendCleanUps=False)</code>| |
| | |<code>indigo.insteon.sendSceneOff(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneOff(11, updateStatesOnly=True)</code>| |
| | |<code>indigo.insteon.sendSceneOff("working in office scene")</code>| |
| | |<code>indigo.insteon.sendSceneOff("working in office scene", sendCleanUps=False)</code>| |
| | ^ Parameters ^^^^ |
| | ==== Send Scene Fast ON ==== |
| | This command will send an INSTEON Scene Fast ON command using the specified PowerLinc scene. |
| | |<code>indigo.insteon.sendSceneFastOn(11)</code>| |
| | |<code>indigo.insteon.sendSceneFastOn(11, sendCleanUps=False)</code>| |
| | |<code>indigo.insteon.sendSceneFastOn(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneFastOn(11, updateStatesOnly=True)</code>| |
| | |<code>indigo.insteon.sendSceneFastOn("working in office scene")</code>| |
| | |<code>indigo.insteon.sendSceneFastOn("working in office scene", sendCleanUps=False)</code>| |
| | ^ Parameters ^^^^ |
| | ==== Send Scene Fast OFF ==== |
| | This command will send an INSTEON Scene Fast OFF command using the specified PowerLinc scene. |
| | |<code>indigo.insteon.sendSceneFastOff(11)</code>| |
| | |<code>indigo.insteon.sendSceneFastOff(11, sendCleanUps=False)</code>| |
| | |<code>indigo.insteon.sendSceneFastOff(11, suppressLogging=True)</code>| |
| | |<code>indigo.insteon.sendSceneFastOff(11, updateStatesOnly=True)</code>| |
| | |<code>indigo.insteon.sendSceneFastOff("working in office scene")</code>| |
| | |<code>indigo.insteon.sendSceneFastOff("working in office scene", sendCleanUps=False)</code>| |
| | ^ Parameters ^^^^ |
| | ==== Send Scene Start Change ==== |
| | This command will tell the specified PowerLinc scene to begin increasing/decreasing in value. It will continue to ramp each device in the scene until either the corresponding [[#Send Scene Stop Change]] command is called or until the devices are at 100% for increase ramping or 0% for decrease ramping. |
| | |<code>indigo.insteon.sendSceneIncrease(11, increase=True)</code>| |
| | ^ Parameters ^^^^ |
| | |//''increase''//| Yes | boolean |True if you want to ramp up, False if you want to ramp down | |
| | ==== Send Scene Stop Change ==== |
| | This command will tell the specified PowerLinc scene to stop any ramping activity started by a [[#Send Scene Start Change]] command. |
| | ^ Parameters ^^^^ |
| | ==== Send Status Request ==== |
| | This command will send an INSTEON Status Request command to the specified address. |
| | |<code>reply = indigo.insteon.sendStatusRequest("0A.B9.DC") |
| | indigo.server.log("reply success: %d, ack value: %02X" % (reply.cmdSuccess, reply.ackValue))</code>| |
| | ^ Parameters ^^^^ |
| | |direct parameter| Yes | string |the target INSTEON address as a hexadecimal string.| |
| | |//''waitUntilAck''//| No | boolean |true if the caller wants to wait for the result. (default is True)| |
| | ==== Send Raw ==== |
| | This command will send a raw INSTEON standard command. |
| | |<code>reply = indigo.insteon.sendRaw("0A.B9.DC", [0x10, 0x00]) |
| | ^ Parameters ^^^^ |
| | |//''cmdBytes''//| Yes | list |a list of 2 integer bytes that represent the command to be sent.| |
| | |//''waitUntilAck''//| No | boolean |True if the caller wants to wait for the result. (default is True)| |
| | |//''waitForStandardReply''//| No | boolean |True if the caller wants to wait for a follow-up direct standard reply. (default is False)| |
| | |//''waitForExtendedReply''//| No | boolean |True if the caller wants to wait for a follow-up direct extended reply. (default is False)| |
| | ==== Send Raw Extended ==== |
| | This command will send a raw INSTEON extended command (command payload can be between 2 and 16 bytes). |
| | |<code># Get KeypadLinc info (LED states, brightness, etc.) |
| | reply = indigo.insteon.sendRawExtended("11.7B.2E", [0x2E, 0x00], waitForExtendedReply=True) |
| | if reply.cmdSuccess: |
| | indigo.server.log(" backlight brightness: %d" % (reply.replyBytes[10],)) |
| | indigo.server.log("button toggle mode bitmap: 0x%02X" % (reply.replyBytes[11],)) |
| | indigo.server.log(" button states bitmap: 0x%02X" % (reply.replyBytes[12],))</code>| |
| | |<code># Change the Keypad LED brightness from dim to bright |
| | setKeypadLedBrightness = [ |
| | 0x2E, 0x00, |
| | 0x00, # unused |
| | 0x07, # change LED backlight brightness |
| | 0x11, # brightness between 0x11 and 0x7F |
| | 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 |
| | for brightness in [0x07, 0x44, 0x66, 0x7F]: |
| | setKeypadLedBrightness[4] = brightness |
| | indigo.insteon.sendRawExtended("11.7B.2E", setKeypadLedBrightness)</code>| |
| | ^ Parameters ^^^^ |
| | |//''cmdBytes''//| Yes | list |a list of 2 to 16 integer bytes that represent the command to be sent.| |
| | |//''calcCrc''//| No | boolean |automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True)| |
| | |//''calc16bitCrc''//| No | boolean |automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False)| |
| | ==== Send PowerLinc SET Button Press Message ==== |
| | This will command the PowerLinc to send its SET Button Press Message, which can be useful in some linking scenarios. |
| | |<code>reply = indigo.insteon.sendPowerLincSetButtonPress()</code>| |
| | ^ Parameters ^^^^ |
