| indigo_7_documentation:managing_z-wave_devices [2016/11/12 20:44] – mattb | indigo_7_documentation:managing_z-wave_devices [2025/04/14 20:10] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Managing Your Z-Wave® Network ====== | ||
| + | Indigo 7 provides several tools to manage your [[:Z-Wave]] network. Not only can you create/ | ||
| + | <color blue> | ||
| + | ===== Adding a Z-Wave Device ===== | ||
| + | Indigo supports a [[http:// | ||
| + | Before proceeding, make sure that you have [[getting_started# | ||
| + | To add a Z-Wave device to Indigo, follow these steps: | ||
| + | - Select '' | ||
| + | - Click the '' | ||
| + | - You'll see the '' | ||
| + | - Follow the directions on the dialog to complete setting up the device. | ||
| + | <color red> | ||
| + | ==== Using Encryption ==== | ||
| + | As mentioned in the dialog, we recommend using encryption only for devices where it is beneficial or required (like locks). Although encryption increases security, it can also degrade responsiveness of the hardware and increase the potential for network congestion and retries. The additional commands required for encryption can also decrease battery life. | ||
| + | ==== Changing Existing Hardware Inclusion to Use Encryption ==== | ||
| + | If you added a device to the network (Z-Wave Controller) without encryption enabled and then wish to enable encryption you must first remove it from the network. This is because the encryption key exchange can only occur with Indigo if the device has just been added to the network (within a few seconds), and before a device can be added to the network it must not be included in any networks. To do this you can use the '' | ||
| + | ==== Moving a Z-Wave Lock from a Different Controller to Indigo ==== | ||
| + | If you have a Z-Wave lock currently included with another controller, you must first exclude the lock from the network before adding it to Indigo with encryption enabled. To do this you can use the '' | ||
| + | ==== Editing a Z-Wave Device' | ||
| + | Once you've defined your device, you can edit its properties. If you've still got the device dialog open, you can skip the first three steps below. | ||
| + | - Find the device in the device table and double-click it (or select it an click the '' | ||
| + | - You'll see the standard '' | ||
| + | - Click on the '' | ||
| + | The top part of that dialog shows some details about the device that will help support when diagnosing problems. | ||
| + | Next, the polling properties for the device are shown if they are applicable to the device type. The first thing you need to determine is if the device needs to be polled to check for status changes. Most devices will require some kind of polling to stay in sync. There are a few devices that Indigo can determine status changes on automatically, | ||
| + | Next, select the desired polling interval. This setting is quite important actually - the more frequently you poll a device the more congested your network will become. In fact, we can't guarantee an exact polling frequency below 5 minutes because we have to watch for the network to become idle before we can try polling. So, we suggest that the less important devices to keep in sync are polled at longer intervals and more critical devices get polled immediately. You can also poll devices that can't or don't get manually operated at a much lower frequency because Indigo will update the state as soon as the command to operate the device is acknowledged. | ||
| + | The top item on the list, '' | ||
| + | The fastest polling option is '' | ||
| + | Also shown in the settings dialog are any configuration parameters specific to that device (in this example the temperature units and display contrast). Indigo only shows settings if there is a custom device profile for a particular device. However, if no settings are shown you can still modify any configuration parameters by using the '' | ||
| + | If a '' | ||
| + | Maintaining our [[http:// | ||
| + | ===== Resyncing and Replacing a Z-Wave Device ===== | ||
| + | Sometimes you may be instructed by support to resync your device - the process is quite simple: | ||
| + | - Find the device in the device table and double click it (or select it and click the '' | ||
| + | - When the '' | ||
| + | This will tell Indigo to query the device and update various information about it and may help with some communication issues. | ||
| + | If a Z-Wave device fails (and depending on the type), you may be able to just replace it with a new one and all Triggers, Conditions, Actions, and Control Pages will continue to work. To replace a device: | ||
| + | - Follow the instructions on the dialog to use your interface to include the device into your network if you haven' | ||
| + | - Select the new device in the '' | ||
| + | - Click on the " | ||
| + | Note that not all devices can be replaced. Specifically, | ||
| + | ===== Deleting a Z-Wave Device ===== | ||
| + | When deleting a Z-Wave device, it's always a good idea to exclude it from your network after you've deleted it in Indigo (if it's still functional). So, the process is this: | ||
| + | - Find the device in the device table and select it. | ||
| + | If the device has any [[indigo_7_documentation: | ||
| + | The last thing you'll want to do is to exclude the device from your network if it's still functional. To do this you can use the '' | ||
| + | ===== Replacing a Z-Wave Controller ===== | ||
| + | You may need to replace your controller. This section describes the steps involved in moving your Z-Wave devices to a new controller. | ||
| + | If your controller doesn' | ||
| + | - Remove your old controller from your Mac. | ||
| + | - Plug your new controller into your Mac and [[indigo_7_documentation: | ||
| + | - Select the '' | ||
| + | - Go to the Z-Wave device closest to your Mac that’s not battery powered (also skip any that require encryption) and perform its exclusion process. | ||
| + | - Go back to your Mac, edit the device you just excluded, click the '' | ||
| + | - Go back to your device and perform its inclusion process (press its LINK button, etc.). | ||
| + | - Return to your Mac (it should say '' | ||
| + | - Repeat steps 3-7 for each non-battery powered device from the closest to your Mac to the furthest. | ||
| + | - Repeat steps 3-7 for each battery powered device or devices that require encryption. | ||
| + | - Finally, select the '' | ||
| + | If your controller has a physical button, you may chose to follow this process because it requires fewer walks from your Mac to the devices being moved to the new controller: | ||
| + | - Remove your old Z-Stick from your Mac. | ||
| + | - Plug your new Z-Stick into your Mac and [[indigo_7_documentation: | ||
| + | - Unplug your new Z-Stick from the Mac and take it to the Z-Wave device closest to your Mac that’s not battery powered (also skip any that require encryption) and exclude it. Note you can exclude from any controller, not just the one it was included with. | ||
| + | - While at the device, include it into the new Z-Stick. | ||
| + | - Plug the new Z-Stick back in to your Mac. | ||
| + | - Open the config dialog for the device you included and click the '' | ||
| + | - Select the new node number from the popup at the bottom and '' | ||
| + | ===== Z-Wave Menu Options ===== | ||
| + | The '' | ||
| + | === Manage Associations === | ||
| + | Indigo supports defining Z-Wave Associations (which are similar to INSTEON links) between devices that support that functionality. Note that battery operated devices which are asleep will need to be woken up (per their instructions manual) for associations to be edited. | ||
| + | === Modify Configuration Parameter === | ||
| + | Some Z-Wave devices provide configuration options through the use of configuration parameters. These are generally outlined in the documentation that comes with a device. Indigo often times support setting these parameters directly in the device config dialog, but because of the sheer number of Z-Wave devices we can't add every one. This menu item will allow you to set any config parameter that a device accepts. | ||
| + | **Note** - this process can cause your device to not function correctly if incorrect parameters are entered so you'll want to make sure you are very careful to use only the params specified for the specific device. | ||
| + | === Send Raw Z-Wave Command === | ||
| + | This menu selection can be used to send arbitrary Z-Wave protocol-level commands to any Z-Wave device. This is generally only useful when Support instructs you to do so. Note battery operated devices allow for the option to queue the command to be sent the next time the device wakes. | ||
| + | === Start Controller Inclusion Mode === | ||
| + | This menu selection puts the Z-Wave Controller into inclusion mode. You can then follow the steps from the device' | ||
| + | === Start Controller Inclusion Mode with Encryption === | ||
| + | This menu selection puts the Z-Wave Controller into inclusion mode with encryption enabled. You can then follow the steps from the device' | ||
| + | === Start Controller Exclusion Mode === | ||
| + | This menu selection puts the Z-Wave Controller into exclusion mode. You can then follow the steps from the device' | ||
| + | === Stop Inclusion / Exclusion === | ||
| + | This menu selection exits both inclusion and exclusion mode. | ||
| + | === Optimize Z-Wave Network === | ||
| + | Indigo can optimize your Z-Wave network by having devices rediscover which devices they are close enough to communicate with. This information is then reported back to the Z-Wave Controller so network routing tables can be updated. | ||
| + | === Remove Failed Device from Controller === | ||
| + | If a Z-Wave device is no longer available to your network (it failed, etc) then you can use this menu item to remove it from the interface. You might need to attempt a Define and Sync on the device (and allow it to fail) just before using this menu item. | ||
| + | === Reset Z-Wave Interface === | ||
| + | You can completely reset your Z-Wave interface by selecting this menu item. You should only do this if instructed by Support. | ||
| + | //Z-Wave® is a registered trademark of Sigma Designs, Inc. Indigo' | ||
