| Next revision | Previous revision | ||
| indigo_7_documentation:plugin_extending_tutorial [2016/02/10 22:21] – external edit 127.0.0.1 | indigo_7_documentation:plugin_extending_tutorial [2025/02/18 20:36] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Indigo Server Plugin Tutorial ====== | ||
| + | Note most of the code examples below are calling methods on the object //'' | ||
| + | ===== Indigo Plugin SDK Source Code Examples ===== | ||
| + | The Indigo Plugin SDK ([[http:// | ||
| + | Included in the SDK are examples that create plugin based relay, dimmer, thermostat, sensor, speed control, sprinkler, energy meter and custom devices. Also included is an example showing basic Indigo database traversal, how to catch low-level X10/INSTEON messages, and how to create an Indigo telnet server using the python twisted framework. | ||
| + | We'll be adding additional example plugins in the future. | ||
| + | ===== Other Useful Plugin Source Code Examples ===== | ||
| + | Additionally, | ||
| + | ^ Plugin task ^ Plugin that illustrates an approach | ||
| + | | Parsing XML from an IP source | ||
| + | | Integrating with native Mac Apps | Airfoil | ||
| + | | Sending RS232 (serial port & network serial port) Commands | ||
| + | | Reading RS232 (serial & network serial port) Input | EasyDAQ | ||
| + | | Interacting with an IMAP mail server | ||
| + | | Creating custom devices with states | ||
| + | | Creating custom actions | ||
| + | | Creating custom events | ||
| + | Each of these plugins is installed by default with Indigo 7 - in the ''/ | ||
| + | Both the SDK example plugins and the plugins included with Indigo above are great places to see working examples of plugins and their source code. | ||
| + | ===== How to Read and Write Plugin Preferences ===== | ||
| + | FIXME (useful, but very rough notes below) | ||
| + | * Per plugin prefs file is automatically managed (created, loaded, updated). | ||
| + | * Pref values can be numbers, boolean, strings, indigo.Dict() or indigo.List(). | ||
| + | * Key values defined in PluginConfig.xml are automatically mapped into the plugin' | ||
| + | self.pluginPrefs[" | ||
| + | * Plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin' | ||
| + | * To read a preference value access its key:< | ||
| + | someVal = self.pluginPrefs[" | ||
| + | indigo.server.log(" | ||
| + | * To create a new or update an existing preference value assign it a new value:< | ||
| + | ===== How to Add Plugin Metadata to Devices, Trigger & Scheduled Events, Variables, etc. ===== | ||
| + | * Most Indigo database objects support the addition of plugin specific metadata. | ||
| + | * Every plugin has its own name space accessed via the object instance //'' | ||
| + | * The pluginProps dictionary supports numbers, boolean, strings, indigo.Dict() or indigo.List(). | ||
| + | * Example adding new plugin metadata to the Device "den fixture":< | ||
| + | dev = indigo.devices[" | ||
| + | newProps = dev.pluginProps | ||
| + | newProps[" | ||
| + | newProps[" | ||
| + | newProps[" | ||
| + | newProps[" | ||
| + | dev.replacePluginPropsOnServer(newProps) | ||
| + | * Example reading the plugin specific property onCycles from the Device "den fixture":< | ||
| + | onCycles = dev.pluginProps[" | ||
| + | * Example incrementing by 1 the plugin specific property onCycles for the Device "den fixture":< | ||
| + | newProps[" | ||
| + | * Plugins have read-only access to other plugin metadata via //'' | ||
| + | * Plugins have read/write access to their own metadata space. | ||
| + | ===== Creating a Custom Plugin Device ===== | ||
| + | * Plugin Device state and properties are defined in Devices.xml. | ||
| + | * Properties define the user configurable options for a device instance, and are specified in the //''< | ||
| + | * States are specified in the Devices.xml //''< | ||
| + | * States defined in Devices.xml are automatically shown in the Trigger Event ''// | ||
| + | * States are read-only for everyone except the plugin that defines the device' | ||
| + | * Plugins should update a device state after it has sent commands to hardware, or somehow received new state information from hardware. Example that increments the plugin defined state ''// | ||
| + | dev.updateStateOnServer(" | ||
| + | * Plugins should subclass ''// | ||
| + | def deviceStartComm(self, | ||
| + | self.easydaq.startCommThread(dev) | ||
| + | def deviceStopComm(self, | ||
| + | self.easydaq.stopCommThread(dev) | ||
| + | * Calls to ''// | ||
| + | ===== Creating a Custom Plugin Trigger Event ===== | ||
| + | FIXME Explain Events.xml. Show example plugin subclasses of functions: triggerStartProcessing, | ||
| + | ===== Monitoring Device State Changes from a Plugin ===== | ||
| + | FIXME Give examples of using indigo.devices.subscribeToChanges() and plugin subclasses of functions: deviceDeleted, | ||
| + | ===== Monitoring Changes to Variables, Triggered & Scheduled Events, Action Groups, and Control Pages ===== | ||
| + | FIXME Give examples of using indigo.*.subscribeToChanges() and plugin subclasses of functions: variableCreated, | ||
