| indigo_7_documentation:plugins:variable_substitution [2017/01/18 17:29] – jay | indigo_7_documentation:plugins:variable_substitution [2025/02/18 20:36] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Substitutions ====== | ||
| + | Plugin writers can enable configuration text fields to accept special markup that will substitute a variable or device state value at runtime. Any string with the following markup will have an Indigo variable value substituted: | ||
| + | VARID is the unique variable ID as found in the UI in various places. | ||
| + | So, for instance, if one of your actions is to use the [[growl_1|Growl plugin]] to do a notification, | ||
| + | The value specified would be substituted just before the notification was sent. | ||
| + | Likewise, if you use the following markup: | ||
| + | The STATEID of the device whose ID is DEVID will be substituted. For instance, an iTunes Server device from the iTunes plugin has a state named **'' | ||
| + | Note - not all text fields will support substitution. The plugin developer must enable it specifically. Check the plugin documentation to see if the field you're interested in supports substitution. | ||
