Link to this comparison view
Next revision
Previous revision
insteon_devices [2009/04/15 19:22] mattbinsteon_devices [2026/04/07 18:27] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +====== Insteon Device Support ======
 +[[Insteon]] is a home automation hardware standard developed by [[http://www.insteon.net|SmartLabs]]. It uses dual-mesh technology to send signals over the power line as well as via RF (only available in North America). If you're unfamiliar with Insteon, you might want to read up on how [[Insteon links]] work. Manufacturers of Insteon compatible products are:
 +  * [[http://www.insteon.net|SmartLabs]]
 +  * [[https://smartenit.com|Smartenit]]
 +You may want to check out an overview of [[inst_define|how to define an Insteon device in Indigo]]. Check out the [[http://www.indigodomo.com/devices/#insteon|Insteon section]] of our supported devices list for a good list of all Insteon devices Indigo supports.
