| ms_sensing_during_specific_times [2011/05/02 21:40] – jay | ms_sensing_during_specific_times [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ====== Motion sensing only during a specific time ====== | ||
| + | So, you have this cool motion sensing light. But, what if you only want the light motion sensing to work between 10pm and dawn? The easiest way is to make a couple Time Date Trigger actions that will enable/ | ||
| + | === Defining the Enable Front Porch Motion Trigger === | ||
| + | - Select '' | ||
| + | - Press the '' | ||
| + | - Name the trigger '' | ||
| + | - Enter '' | ||
| + | - Choose the '' | ||
| + | === Defining the Disable Front Porch Motion Trigger === | ||
| + | That's it! Now, the motion sensing will only happen between 10pm and sunrise. | ||
| + | In Indigo 5 and greater, we significantly enhanced the condition editor and added a bunch of new conditions. One new condition is the ability to specify time ranges. So, rather than making two triggers as above, simply define the triggers as specified in the [[ms_porch_light|Motion Triggered Porch Light]] scenario - except on the Conditions tab specify "If time" "is between" | ||
