| plugins:user_scripts [2011/11/18 16:05] – mattb | plugins:user_scripts [2025/11/04 15:41] (current) – davel17 |
| | ====== User Scripts Plugin ====== |
| | Install this plugin if you would like to add AppleScript or Python script files to Indigo's Plugins menu. |
| | To install, [[http://www.indigodomo.com/pluginstore/150/|download the plugin]], unzip it, then double-click the **User Scripts.indigoPlugin** file to install. |
| | Next, control-click (or right-click) on this file and choose **''Show Package Contents''** from the context menu (depending on which version of Indigo you're using): |
| | /Library/Application Support/Perceptive Automation/Indigo 5/Plugins/User Scripts.indigoPlugin |
| | /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/User Scripts.indigoPlugin |
| | /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/User Scripts.indigoPlugin |
| | /Library/Application Support/Perceptive Automation/Indigo VERSION/Plugins/User Scripts.indigoPlugin |
| | And then add any AppleScript (.scpt) or Python (.py) files into the folder: |
| | User Scripts.indigoPlugin/Contents/Menu Items/ |
| | Lastly, choose the **''Plugins->User Scripts->Reload Plugin''** menu item. |
| | Your scripts should then be accessible from the //''<nowiki>/Plugins/User Scripts</nowiki>''// menu item. |
| | <color #ed1c24>NOTE:</color> If you make changes to the contents of the //''<nowiki>/Plugins/User Scripts</nowiki>''// folder -- such as deleting a file that was already there or renaming a file in the folder, you may need to exit and restart the Indigo client for all the changes to take effect. |
