| Both sides previous revision Previous revision | |||
| powerline_signal_troubleshooting [2018/08/23 19:46] – [Temporarily Remove or Filter Noisy Electronics] jay | powerline_signal_troubleshooting [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ===== Insteon and X10 Troubleshooting Basics ===== | ||
| + | Insteon and X10 are both power line protocols that allow remote control and monitoring of modules through your existing home wiring. Insteon is a newer, more robust standard that provides improved performance and signal reliability. There are dozens of different Insteon and X10 [[http:// | ||
| + | Insteon is also dual-band, which means that it sends signals both on the power line and wirelessly. Most Insteon devices that are not battery powered and have shipped since 2014 or so are dual-band. That is, the send and receive signals from both the power line and from RF. It's worth noting however that these dual-band devices often prioritize power line signals over RF. That means that if there is signal noise on the power line, the device may still fail to operate reliably even though it's dual-band. | ||
| + | ==== Signal Troubleshooting ==== | ||
| + | In some cases Insteon or X10 control modules fail to receive or properly decode the information sent over the power line. This typically happens because there is excessive noise on the power line caused by some other appliance, such as a power supply, surge protector strips, portable electronics charger, etc., or because the signal is not able to travel over that particular leg, or phase, of your household wiring. | ||
| + | The most common symptom of a signal problem is when some Insteon or X10 modules are controllable, | ||
| + | === Bridge Your Home's 110V Power Legs === | ||
| + | Every house has two 110V power legs that are electrically connected only at the street or alley transformer. Most Insteon devices that shipped over the past several years that aren't battery powered are dual-band, which means that they repeat over both the power line and RF. If you have older devices, then properly installing two [[https:// | ||
| + | **Important**: | ||
| + | === Change the Insteon / X10 Signal Path === | ||
| + | Sometimes just changing the signal path from the transmitting computer interface (PowerLinc, CM11, etc.) to the destination module can help. Try the following, attempting to turn the module on/off after each step: | ||
| + | Plug the computer interface into a different outlet. If needed, use a short extension cord to reach another outlet. | ||
| + | If the destination module is a plug-in type (LampLinc, ApplianceLinc, | ||
| + | Insteon users can move their AccessPoint RF pair (or SignaLinc RF pair) to other outlets in the house. Per their instructions, | ||
| + | Insteon users can also plug one of the AccessPoint RFs directly into the PowerLinc' | ||
| + | === Temporarily Remove or Filter " | ||
| + | Some electronics can significantly attenuate, or diminish, the strength of Insteon and X10 signals. Uninterruptible Power Supplies (UPSs) and high-end surge protector strips are notorious for attenuating both Insteon and X10 signals. Try temporarily unplugging all UPSs (just let them run off of battery for a couple of minutes) to see if that allows control of the module. If it does, then you can isolate the UPS so that it doesn' | ||
| + | In addition to UPSs, try temporarily unplugging other electronics and surge protector strips that are on the same circuit as the PowerLinc. Potential problem devices include: | ||
| + | * UPSs and surge protector power strips | ||
| + | * televisions and video game systems | ||
| + | * laptop and mobile phone chargers | ||
| + | * fax machines | ||
| + | * MIDI musical instruments | ||
| + | If unplugging any of them helps, then you can isolate the problem device with an [[https:// | ||
| + | === Temporarily Remove or Filter Noisy Electronics === | ||
| + | Some electronics can also introduce noise on the power lines that can cause problems for Insteon and X10 signal reliability. Try temporarily unplugging the following, especially if they are on the same power circuit as the home control computer interface (PowerLinc, CM11, etc.) or the module you are trying to control: | ||
| + | * portable electronic chargers (laptop, mobile phone, tooth brushes, razors, etc.) | ||
| + | * CFL, LED, halogen and HID lighting | ||
| + | * fans, treadmills, and other appliances with motors | ||
| + | === Identify failing X10 (and Insteon) Devices === | ||
| + | If you see traffic from X10 device addresses for which you don't have a corresponding device, it is possible that you have another X10 or Insteon device that's starting to fail and is erroneously broadcasting out garbage that looks to the interface like valid X10 traffic. The interface may become so busy trying to decipher these garbage transactions that it will not reliably send commands. You'll need to find the offending device and disable it. | ||
| + | With plug-in modules that's simple, just unplug them all and start adding them back one at a time. It's a bit harder with devices that are in-wall. Some of these devices have the ability to be " | ||
| + | === Increase the Insteon / X10 Signal Strength === | ||
| + | Although we recommend making sure your power legs are bridged correctly (see above) and isolating problem electronics first (see above), if you still have unreliable operation with some modules then you can try increasing the signal strength with a signal repeater or booster. All Insteon modules are automatically repeaters (of Insteon commands only), so adding additional modules (LampLinc, ApplianceLinc, | ||
| + | X10 commands are only repeated by an active couple repeater, like the dryer SignaLinc Coupler Repeater. Another option besides repeating the command is to use a signal booster, like the BoosterLinc. Note the BoosterLinc only boosts X10 signals. | ||
| + | ==== Signal Isolation Steps ==== | ||
| + | When diagnosing issues, the most thorough practice is to isolate which circuit appears to have the most problems. As described above, changing the signal path may help you identify specific circuits that have issues. A more definitive approach is to check circuits individually. Start by turning off all circuits in your house except the one with your Mac and PowerLinc. Make sure that all devices on that circuit work correctly. Then, turn the circuits back on one by one and check all the devices on all active circuits. When you start experiencing failures (no acknowledgements with Insteon), then it's likely that the most recently turned on circuit has something that's causing the noise. You can then start unplugging/ | ||
| + | Repeat this process as necessary until you can isolate the problem areas and devices. | ||
| + | ==== Getting More Help ==== | ||
| + | Still having a problem? Perform the following troubleshooting steps and send the results to us in an email, or to draw on the expertise of the entire Indigo community, post the results on our active [[https:// | ||
| + | - Choose the '' | ||
| + | - Press the '' | ||
| + | - From the Main Window select the Devices list and the Device you want to control, then press the '' | ||
| + | - **Question**: | ||
| + | - If the Device module is a plug-in type (LampLinc, ApplianceLinc, | ||
| + | - Select the Event Log window, then select all the logged text and copy/paste it into a [[https:// | ||
