| Both sides previous revision Previous revision | |||
| x10_security_events [2010/09/14 21:36] – adrius42 | x10_security_events [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | === X10 Security Events === | ||
| + | == Event Types == | ||
| + | Commands are normally manually created by human intervention on a Remote Control, whereas Detection occurs when a device is triggered by the event that it was designed to detect.\\ | ||
| + | - sec_ArmHome_min - Command: Arm home with minimum delay to action the arming | ||
| + | - sec_ArmHome_max - Command: Arm home with maximum delay to action the arming | ||
| + | - sec_ArmAway_min - Command: Arm home with minimum delay to action the arming | ||
| + | - sec_ArmAway_max - Command: Arm home with maximum delay to action the arming | ||
| + | - sec_Disarm | ||
| + | - sec_Panic | ||
| + | - sec_LightsOn | ||
| + | - sec_LightsOff | ||
| + | - sec_SensorNormal_min - Detection: Sensor reset with minimum delay prior to enactment, Door or Window Closed or Motion No Longer Detected | ||
| + | - sec_SensorNormal_max - Detection: Sensor reset with maximum delay prior to enactment, Door or Window Closed or Motion No Longer Detected | ||
| + | - sec_SensorAlert_min | ||
| + | - sec_SensorAlert_max | ||
| + | Thus, to evaluate what response is appropriate it is necessary to evaluate both the event and the device type. | ||
