| Both sides previous revision Previous revision | |||
| zwave_devices:eurotronic [2013/09/15 18:48] – mattb | zwave_devices:eurotronic [2026/04/07 18:27] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | ===== Stella-Z ===== | ||
| + | Based on user feedback, it sounds like it can be difficult to make the Stella-Z stay awake during the Define/Sync process but it should eventually complete if you continue to wake the module. | ||
| + | You will likely want to change the wake interval in the '' | ||
| + | Indigo maps the following thermostat modes to what the Stella-Z supports: | ||
| + | * Off -> Frost Protection Mode (there is no real " | ||
| + | * Heat -> Comfort Mode | ||
| + | * Cool -> Undefined (don't use) | ||
| + | * Auto -> Undefined (don't use) | ||
| + | There is no way currently to use Indigo to put it into the Energy Saving or Direct Control Modes. Energy Saving mode can be simulated by changing the setpoint values. | ||
| + | Based on feedback it sounds like the Stella-Z doesn' | ||
| + | [[http:// | ||
| + | [[https:// | ||
