Table of Contents
Folders
The folder class represents a folder in the various Indigo user interfaces (Mac client, Indigo Touch, web, etc.).
Class Properties
Property Type Description
id integer the unique id of the folder, assigned on creation by IndigoServer
name string the name of the folder - no two folders in the same namespace (i.e. indigo.devices) can have the same name
remoteDisplay boolean should this folder be displayed in remote clients (IWS, Indigo Touch, etc)
Commands (indigo.*.folder.*)
The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder.*, indigo.variables.folder.*, etc).
Create
Create a folder. This method returns a copy of the newly created folder.
Command Syntax Examples
indigo.variables.folder.create("Folder Name Here")
Parameters
Parameter Required Type Description
name Yes string the name of the folder
Delete
Delete the specified folder.
indigo.devices.folder.delete(123, deleteAllChildren=True)
Parameters
direct parameter Yes integer id or instance of the folder to delete
deleteAllChildren No boolean a boolean to specify whether all objects contained in the folder should be deleted as well - defaults to False
Duplicate
Duplicate the specified folder. This method returns a copy of the new folder.
indigo.controlPages.folder.duplicate(123, duplicateName="New Name")
Parameters
direct parameter Yes integer id or instance of the folder to duplicate
duplicateName No string name for the newly duplicated folder
Get ID
Returns the ID of the named folder under the specified object type (device, trigger, etc).
indigo.device.folder.getId("Some Folder Name")
Parameters
direct parameter Yes string name of any folder for the specified object type.
Set Remote Display
Use this command to set the remote display flag for the folder.
indigo.schedules.folder.displayInRemoteUI(123, value=False)
Parameters
value Yes boolean True to display the folder on remote user interfaces or False to hide it
Examples
Since folders aren't available in AppleScript, we're only providing Python examples here.
# create a new variable folder
newFolder = indigo.variables.folder.create("My New Variable Folder")
# test to see if a folder exists by Name
if ("My New Variable Folder" in indigo.variables.folders):
    # should execute this because we just created it
    indigo.server.log("folder named 'My New Variable Folder' exists")
# test to see if a folder exists by ID
if (newFolder.id in indigo.variables.folders):
    indigo.server.log("folder id " + newFolder.id + " exists")
# set the remote display flag on the folder immediately
indigo.variables.folder.displayInRemoteUI(newFolder, value=False)
# a ValueError exception with the text "NameNotUniqueError" is thrown if you try to
# create a folder with a name that already exists
except ValueError, e:
    if str(e) == "NameNotUniqueError":
        # should execute this because it's a dup name
        indigo.server.log("folder named 'My New Variable Folder' already exists")
        indigo.server.log("Some other error")
# NOTE - at this point, newFolder.remoteDisplay is still true (default for new folders)
# because we're still working with a copy. Refresh it to get it updated:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.name="My Variable Folder"
newFolder.replaceOnServer()
# duplicate the folder
indigo.variables.folder.duplicate(newFolder, duplicateName="My Duplicate Folder")
# delete a folder
indigo.variables.folder.delete(newFolder)
#test to see if a folder doesn't exist using name
if ("My New Variable Folder" not in indigo.variables.folders):
    # should execute this because we just deleted it
    indigo.server.log("folder named 'My New Variable Folder' does not exist on the server")
# test to see if a folder doesn't exist using ID (was deleted perhaps)
if (newFolder.id not in indigo.variables.folders):
    indigo.server.log("folder id " + newFolder.id + " does not exist on the server")
