This version of the API shipped with Indigo 7.5.0 - check the API Version Chart to see what version of the API is available in which Indigo versions.
indigo.server.getPluginList()
and check if a plugin instance is installed plugin.isInstalled()
.level
argument to the indigo.server.log()
method to specify the python logging level that will determine the Event Log window text color used. Possible values include: logging.INFO
(black), logging.WARNING
(orange), logging.ERROR
(red). The default plugin instance logger will also now map self.logger.warn()
to use an orange text color as well. Example usage:import logging indigo.server.log("info log message which will show in black text", level=logging.INFO) indigo.server.log("warning log message which will show in orange text", level=logging.WARNING) indigo.server.log("error log message which will show in red text", level=logging.ERROR) # Equivalent of above server API calls that instead use the plugin instances default logger instance: self.logger.info("info log message which will show in black text") self.logger.warn("warning log message which will show in orange text") self.logger.error("error log message which will show in red text")
