indigo.insteon.sendSceneDecrease(11)
indigo.insteon.sendSceneDecrease(11, repeatCount=5)
indigo.insteon.sendSceneDecrease(11, suppressLogging=True)
indigo.insteon.sendSceneDecrease(11, updateStatesOnly=True)
indigo.insteon.sendSceneDecrease("working in office scene")
repeatCount No integer a value from 1-32 for the number of times to repeat the decrease (default is 1)
suppressLogging No boolean True if entries in the event log should be suppressed (default is False)
indigo.insteon.sendSceneIncrease(11)
indigo.insteon.sendSceneIncrease(11, repeatCount=5)
indigo.insteon.sendSceneIncrease(11, suppressLogging=True)
indigo.insteon.sendSceneIncrease("working in office scene")
repeatCount No integer a value from 1-32 for the number of times to repeat the increase (default is 1)
sendCleanUps No boolean True if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)
This command will tell the specified PowerLinc scene to begin increasing/decreasing in value. It will continue to ramp each device in the scene until either the corresponding Send Scene Stop Change command is called or until the devices are at 100% for increase ramping or 0% for decrease ramping.
indigo.insteon.sendSceneIncrease(11, increase=True)
increase Yes boolean True if you want to ramp up, False if you want to ramp down
This command will tell the specified PowerLinc scene to stop any ramping activity started by a Send Scene Start Change command.
direct parameter Yes string the target INSTEON address as a hexadecimal string.
waitUntilAck No boolean true if the caller wants to wait for the result. (default is True)
cmdBytes Yes list a list of 2 integer bytes that represent the command to be sent.
waitUntilAck No boolean True if the caller wants to wait for the result. (default is True)
waitForStandardReply No boolean True if the caller wants to wait for a follow-up direct standard reply. (default is False)
waitForExtendedReply No boolean True if the caller wants to wait for a follow-up direct extended reply. (default is False)
if reply.cmdSuccess:
	indigo.server.log("     backlight brightness: %d" % (reply.replyBytes[10],))
	indigo.server.log("     button states bitmap: 0x%02X" % (reply.replyBytes[12],))
setKeypadLedBrightness = [
	0x2E, 0x00,
	0x00,			# unused
	0x07,			# change LED backlight brightness
	0x11,			# brightness between 0x11 and 0x7F
cmdBytes Yes list a list of 2 to 16 integer bytes that represent the command to be sent.
calcCrc No boolean automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True)
calc16bitCrc No boolean automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False)
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/insteon_specific_commands.txt
