If you are using a PowerLinc or CM15 then enable it as described in the Connecting INSTEON and X10 Power Line Interfaces document.
The process for connecting X10 RF Interfaces is basically the same as for power line interfaces - you just need to select the correct serial port. The W800USB will require installing the FTDI drivers mentioned above. You only need to use this interface if you're using a separate X10 RF interface like the W800 or MR26.
X10 RF Configuration Dialog Image
TIP: You may also need to bridge the two phases of your power line to get reliable communication. Search for “X10 signal bridge” in your favorite search engine for details.
To add an X10 device, select DEVICES in the outline view (or one of it's sub-folders) and click the New… button. Select X10 from the Type: popup and you'll see the following:
X10 Device Detail Image
However, you may have a device module not currently listed in the Type popup menu. To use devices that are not defined in the device Type popup, you can click the Definition… button you will be shown the Module Definition dialog:
X10 Definitions Dialog Image
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/managing_x10_devices.txt
