Alexa
Alexa is a voice recognition system from Amazon which is integrated into many devices, including the Echo devices from Amazon, sound bars and smart speakers, watches, thermostats, TVs, headphones, etc., from a variety of manufacturers.
Smart Home Skill
- Open the Alexa App.
- Go to the Devices list and click the link to Your Smart Home Skills.
- Click Enable Smart Home Skills.
- Tap the Search icon.
- Search for “Indigo Smart Home”. You should see a skill named Indigo Smart Home Skill in English speaking regions and Indigo Smart Home everywhere else, with an icon that matches the logo of the Mac Client.
- Add the skill.
- Link the skill to your Indigo Account & license (currently by clicking/tapping the Settings button).
- Log in using your Indigo Account username and password.
- On the next page (the authorization page), if you have multiple Indigo Licenses, make sure you have the correct one selected (you must have an active Indigo Up-to-Date subscription); you can link one license to one Alexa (Amazon) account. If you see something else or don't see a license you were expecting to see, check the Account Linking Issues troubleshooting section below for help.
Alexa Store Links
Device Types Supported
- On/Off devices (sometimes referred to as relay) - simple appliance control plug-in modules, outlets, and switches are the most common type. This also includes Locks and Garage Doors.
- Dimmer devices - dimmer switches and plug-in modules are the most common, though in Indigo there are a variety of other device types that Indigo sees as dimmers: Blinds/Drapes, Fans, Bulbs (including color), etc.
- Thermostats
- Fans - Indigo natively only supports the Insteon FanLinc fan as a proper fan device (with the right controls) - Z-Wave fan controllers are currently implemented as dimmers, but they will work as fans in Alexa if configured correctly.
On/Off Devices
- Alexa, turn on office lamp
- Alexa, turn off bedroom fan
- Alexa, open garage door
The options are:
- Door Bell - as of this release, this will only allow you to turn on/off the doorbell, not accept ring events. We will look at adding that in a future release.
- Door Controller - if you have a device that physically operates a door (but not a garage door), you can use this device type. You can then say things like:
- Alexa, open the front door
- Alexa, what's the status of the front door
- Garage Controller - this is exactly what you think it is. You will be able to open/close (raise/lower) your garage door. Alexa uses this control type as a more secure option. When Alexa first discovers a garage door, it will not allow you to control the door by voice. Rather, it will tell you to control it manually or go to the Alexa app and configure the door for use with voice control. In the settings for the door in the Alexa app, you will be able to enter a 4 digit PIN for extra security. When you ask Alexa to open or raise the door, you will be prompted for your PIN code. If you have an automatic door controller (specified above) and want the extra security of a PIN code, you can select Garage Controller as well and it should work just like a garage door. PIN codes are set per device so each can be different. You can say things like:
- Alexa, open the garage door
- Alexa, is the garage door open
- Lock - similar to a garage door, a lock device will need to have a PIN assigned for it in the Alexa app. Once that's done, when you attempt to unlock the door (Alexa, unlock the back door), it will prompt you for the PIN. You can say things like:
- Alexa, lock the back door
- Alexa, is the back door locked
- All the rest of the types will simply respond to standard on/off commands. There is currently no distinction other than the icon that shows up in the Alexa app. You can say things like:
- Alexa, turn on bathroom exhaust fan
- Alexa turn off desk lamp
Dimmer Devices
- Alexa, brighten office lamp to 35%
- Alexa, dim office lamp by 15%
- Alexa, set color of office bulb to red (color devices)
- Alexa, set office bulb to daylight (white color temperature)
- Alexa, make office bulb warmer (white color temperature)
| Shades of White | Temperature in Kelvin |
| warm, warm white | 2200 |
| incandescent, soft white | 2700 |
| white | 4000 |
| daylight, daylight white | 5500 |
| cool, cool white | 7000 |
The options are:
Blind- use this type if your dimmer device actually controls blinds, shades, or drapes. You can say things like:- Alexa, raise the blinds to twenty-five percent
- Alexa, set the drapes to fifty percent
- Alexa, close the shades
- Alexa, what is the status of the shades
Fan- use this type if your device actually controls a fan (as of this release Z-Wave fan controllers are treated as dimmers in Indigo). Fan devices from Indigo in Alexa will support 4 modes: Off, Low, Medium, High. You can say things like:- Alexa, set ceiling fan to medium
- Alexa, set ceiling fan to highest
- Alexa, ceiling fan speed
- Alexa, turn off ceiling fan
Valve- use this type if your device controls a valve, or really any device that has a 0-100% range. You can say things like:- Alexa, set set the valve to thirty percent
- Alexa, increase valve by ten percent
- Alexa, turn off the valve
- All the rest will support standard on/off and dim/brighten. If the device supports color and/or white color temperature, those commands will be added to the standard on/off and dim/brighten commands (see the examples above). There is currently no distinction other than the icon that shows up in the Alexa app.
Indigo Fan Devices
- Alexa, increase ceiling fan speed
Indigo Thermostat Devices
- Alexa, set the thermostat to cool
- Alexa, what is my thermostat set to
- Alexa, turn off the heat (Warning: this will turn the thermostat off regardless of mode)
- Alexa, set the AC to seventy-five
- Alexa, make it warmer in here
Custom Indigo Skill
- US, UK - “indigo” is the invocation
- CA, AU - “indigo home” is the invocation
- Alexa, ask Indigo to get “current_weather_conditions”
- Alexa, ask Indigo to look up “current_weather_conditions”
- Alexa, ask Indigo to read “current_weather_conditions”
- Alexa, ask Indigo to say “current_weather_conditions”
- Alexa, ask Indigo to speak “current_weather_conditions”
- Alexa, ask Indigo to tell me “the_status_of_the_house”
- Alexa, ask Indigo for the value of variable “current_weather_conditions”
- Alexa, ask Indigo the value of “current_weather_conditions”
- Alexa, ask Indigo the current value of “weather_conditions”
- You can use Speech Synthesis Markup Language (SSML) to mark up the text in a variable to customize how Alexa reads back the value. Any variable value that begins with a less than sign (<), which we use as a key that the text contains SSML, will be read exactly as specified in the variable without any additional words (i.e. The value of variable won't be prepended). If your markup text doesn't naturally begin with a markup tag, wrap the entire string in
<speak></speak>tags. - Variable values that contain the device (%%d:deviceId:deviceState%%) or variable (%%v:variableId%%) markup values will be correctly substituted by Indigo.
- You may also specify in the plugin's config that all variable values should be read exactly as they are stored without the added verbiage.
Get a List of Variables
- Alexa, ask Indigo to get my variable list
- Alexa, ask Indigo to list my variables
- Alexa, ask Indigo to list all variables
- Alexa, ask Indigo what variables are available
Execute an Action Group
- Alexa, tell Indigo to arm “the kitchen zone”
- Alexa, tell Indigo to do “my favorite thing”
- Alexa, tell Indigo to execute “toggle music”
- Alexa, tell Indigo to launch “rocket”
- Alexa, tell Indigo to make “the house secure”
- Alexa, tell Indigo to perform “routine maintenance”
- Alexa, tell Indigo to play “my favorite playlist”
- Alexa, tell Indigo to reset “the alarm”
- Alexa, tell Indigo to restart “the laundry timer”
- Alexa, tell Indigo to restore “the standard speaker set”
- Alexa, tell Indigo to run “routine maintenance”
- Alexa, tell Indigo to start “the laundry timer”
- Alexa, tell Indigo to set “the playlist to classic rock”
Alexa Plugin operations
Plugin Startup
Started plugin "Alexa 2021.1.0" Alexa Finding devices to publish to Alexa... Alexa ... '010 - Smart Fan Control (14287)' published as 'office fan' Alexa ... '016 - Plug-In Appliance Module (ZL-PA-100)' published as 'office lamp' Alexa ... '038 - Lamp Module (AD130)' published as 'blinds' Alexa ... 'automatic door' published Alexa ... 'FanLinc - Fan' published as 'ceiling fan' Alexa ... 'FanLinc - Light' published as 'fan light' Alexa ... 'Fortrezz Strobe' published as 'strobe' Alexa ... 'Hue Bulb' published as 'office bulb' Alexa ... 'Insteon Dimmer' published as 'valve' Alexa ... 'Insteon On/Off' published as 'back door' Alexa ... 'Insteon Thermostat' published as 'thermostat' Alexa ... 'Kasa Plug' published as 'garage door' Alexa ... 'Office Siren' published Alexa ... 'outlet' published Alexa ... 'Simple Virtual On/Off' published as 'simple switch' Alexa A total of 15 devices are currently published to Alexa Alexa Warning If you can't control a device, rerun discover from your Alexa device.
Showing Publications
Alexa Currently published devices (Alexa name first if different than Indigo name):
Alexa 'Office Siren' ('Office Siren') - Type: RelayDevice - Subtype: Siren
Alexa 'automatic door' ('automatic door') - Type: RelayDevice - Subtype: Door Controller
Alexa 'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock
Alexa 'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind
Alexa 'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None
Alexa 'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer
Alexa 'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller
Alexa 'office bulb' ('Hue Bulb') - Type: DimmerDevice - Subtype: Color Bulb
Alexa 'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan
Alexa 'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In
Alexa 'outlet' ('outlet') - Type: RelayDevice - Subtype: Outlet
Alexa 'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch
Alexa 'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In
Alexa 'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None
Alexa 'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Discovery Requests from Alexa
Alexa ...'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None
Alexa ...'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch
Alexa ...'upstairs siren' ('Fortrezz Siren') - Type: RelayDevice - Subtype: Siren
Alexa ...'outlet' - Type: RelayDevice - Subtype: Outlet
Alexa ...'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer
Alexa ...'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan
Alexa ...'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock
Alexa ...'automatic door' - Type: RelayDevice - Subtype: Door Controller
Alexa ...'Office Siren' - Type: RelayDevice - Subtype: Siren
Alexa ...'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None
Alexa ...'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind
Alexa ...'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In
Alexa ...'office bulb' ('Hue Bulb') - Type: RelayDevice - Subtype: Plug-In
Alexa ...'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In
Alexa ...'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller
Alexa ...'outside lights' ('Outdoor Appliance Module (45604)') - Type: RelayDevice - Subtype: Plug-In
Alexa ...'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Alexa Found 17 devices to publish, replying
Command Requests from Alexa
Full Switch
- Disable the Alexa-Hue Bridge plugin.
- In the Alexa web site, remove all devices. The simplest way is to click the
Remove Allbutton at the bottom. Note, if you are using other smart home skills, using that button will also cause those devices to be forgotten, so when you do a discover later you'll need to perform any steps needed to make discover work on for that skill. - In Indigo, follow the directions above in the Making a Device Available in Alexa to publish your devices.
- Once you have all your devices published, you can confirm that they are all published by selecting the
Plugins→Alexa→Show Device Publicationsmenu item and it will print the list of publications in the Event Log window. - In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say “discover devices”.
Partial Switch
- Disable the device from the Alexa-Hue Bridge plugin (see the docs for the plugin for details). This is very critical in order to avoid complications/confusion later.
- In the Alexa web site, remove that specific device.
- In Indigo, follow the directions above in the Making a Device Available in Alexa to publish your device. Be sure to confirm/select the appropriate subtype.
Alexa Troubleshooting
Device Caching
- You have previously linked your license to Alexa but haven't revoked it on the Authorizations page in your Indigo Account. This may happen if you disable the Indigo Skill then attempt to re-enable it. Click on the Revoke button next to the Alexa authorization for your license to revoke the authorization then try linking again.
- Your Indigo Up-to-Date subscription has expired. To use Alexa (and similar types of integrations), you need to have an active Indigo Up-to-Date subscription and your reflector must be active.
- Your Indigo License doesn't have an active/working Indigo Reflector (included with your UTD subscription). To use Alexa (and similar types of integrations), you need to have an active Indigo Up-to-Date subscription and your reflector must be active.
Changing the Indigo Name
Changing the Device Type
- In the Alexa app, remove the device.
- Go back to the Publication Dialog, select the device, and make sure that you are satisfied with the subtype (or change it as necessary).
- Save any changes.
- Rerun discovery in Alexa.
General Issues
- Make sure that you have enabled the Indigo Skill and linked it to your Indigo Account & license successfully
- Make sure that your Indigo Up-to-Date subscription is active.
- Ensure that your Indigo Reflector is configured and connected. Check this by hitting your reflector URL in a browser: https://YOURREFLECTORNAME.indigodomo.net/
Alexa can't find a device
- Watch the Event Log window for discovery requests
- If you don't see any discovery requests:
- Make sure that your reflector is up and running
- Make sure your Indigo Up-to-Date subscription hasn't lapsed
- Make sure you have OAuth enabled in the Start Local Server dialog
- If you see a discovery request:
- Make sure that the device you are publishing is in the list. Take note of the names of your published devices to ensure that they are unique - if you publish two devices with the same name Alexa will ignore or both of them.
- If the above step is fine, then make sure that you aren't using a name that's used by a device in some other smart home skill (some users use the Hue skill to directly control Hue lights, if you have the Alexa-Hue Bridge plugin enabled that may also be publishing a device with the same name).
- Make sure that you are giving Alexa enough time to update its caches - 10 minutes after a discovery is the recommended wait time.
- If you have a slow or unreliable internet connection, Alexa can timeout a request rather quickly and will speak some error message. If you see inconsistent behavior, this may be a hint that there is some kind of internet connection issue between the Alexa hosted servers and your Indigo Server (see below for more details).
- The v2021.1.0 version of the skill has an issue when a device contains an empty string “” as the device's address. If you look at the device's Address column in the device list and see nothing, that's an indication that it likely will cause a discovery failure (of all devices, not just the one with the bad address). Unpublish the device and try discovery again and it will likely work. We will override devices that have empty strings as the address in the v2021.1.1 release (TBD), but contact the plugin developer in the meantime and see if they have a fix.
Alexa can't control a device
- Make sure you are clearly saying the device name. Alexa can sometimes hear something slightly different than what you're saying.
- Make sure you have the device published in the plugin. You can do this by selecting the
Plugins→Alexa→Show Device Publicationsmenu item. Verify that you are saying the name that is published to Alexa if it's different than the name of the device in Indigo. - Rerun discovery from the Alexa app for an Alexa device.
- Look in the Event Log window for errors when trying to control the device.
- Make sure that the value doesn't contain any SSML markup symbols by themselves, like <, >, /, etc. Alexa will just throw a very unhelpful error (“Sorry, I'm having trouble accessing your Indigo Skills skill right now”) when it thinks that the string contains malformed SSML.
- Make sure that the value of the variable is less than 8000 characters - that's the speech output limit for Alexa.
- If you have too many variables, you may get the error “There is a problem with the requested skill response”. The issue is that the speech output sent to Alexa can't be longer than 8000 characters, so if you have a lot of variables or lots of variables with long names you may run into this situation. The next release of the plugin will only speak variables that have the “Remote Display” flag set for them, so you will be able to exclude variables using that mechanism without deleting them.
