Email+
The Email+ plugin is based on the Better Email plugin, which has been around for many years and is rock solid. With Indigo 2021.1 and the port to the M1 processor, we decided it was time to move away from our very old email solution to something that was newer and had more features. The plugin author graciously allowed us to include it with Indigo. We changed the name to avoid any confusion.
Note: this plugin was added in the Indigo 2021.1 installer. If you were using the Better Email plugin from the Plugin Store before you upgraded, the upgrade process should have worked seamlessly and you shouldn't need to do much. The one thing you may need to change are any scripts that send emails using the Better Email plugin: you will need to change the id to com.indigo.email (see the Scripting Emails section below for details). The same applies to other plugins that were subscribing to broadcast messages.
Use the Email+ forum for questions about this plugin. For users of Indigo prior to 2021.1, we highly recommend that you use the Better Email Plugin (which we've left in the Plugin Store). You won't be able to install Better Email in Indigo versions starting with 2021.1 since they are basically the same plugin.
Email Devices and Usage
You will need to confirm your settings with your email provider. We highly recommend using a dedicated email address for Indigo, particularly if you are performing email scans.
Sending an Email
In the Actions tab, you can use the Notification Actions→Send Email action to send an email:
The format can be either plain text or HTML (it is your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it). Variable (%%v:VariableIDHere%%) and device state (%%d:DeviceIDHere:StateIDHere%%) substitutions are available in all fields, and you can specify attachments by entering the full path to a file, each file separated by commas.
Sending Event Log Data
In the Actions tab, you can use the Email+ Actions→Send Indigo Log Email action to send parts of your Event Log lines:
Email Queue Management Menu Items
You can use the Plugins→Email+→Clear All Email Queues to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
You can use the Plugins→Email+→Clear Email Queue… to clear out the email queue for a specific SMTP server.
Receiving Emails
IMAP Server
Leave in INBOX(default) - this is the safest option if you are using this email address for other things. It can lead to an ever growing email list, so you'll need to delete messages yourself once you're sure you are done with them.Delete Message- if you are using a dedicated email address for Indigo, this is a good option since it will delete a message after it's been processed. This will keep the inbox from growing uncontrollably.Move Message- this is a compromise of the two options above: it keeps the INBOX clean but it also keeps all emails if you want to manually manage them.
IMAP Mailbox Naming
- Processed
- INBOX/Processed
- INBOX.Processed
POP Server
Incoming Email Events
String Match in Email- this event will allow you to perform exact matches in the subject or body of an email, or the sender of the email.RegEx Pattern Match in Email- this will allow you to use regular expressions to match some subset of text in the above 3 fields.Server Connection Error- this will fire a trigger when there is some kind of error in any of the 3 server types above.
Broadcast Messages
MessageType: messageReceived
Returns dictionary:
'messageFrom': <text string>,
'messageTo': <text string>,
'messageSubject': <text string>,
'messageText': <text string>
MessageType: messageSent
Returns dictionary:
Tips on IMAP Mailbox Naming
- Processed
- INBOX/Processed
- INBOX.Processed
Scripting Emails
indigo.server.sendEmailTo("[email protected]", subject="Subject of email", body="Body of email")
plugin = indigo.server.getPlugin("com.indigodomo.email")
if plugin.isEnabled():
plugin.executeAction("sendEmail", deviceId=12345678, props={'emailTo':'[email protected]', 'emailSubject': subject, 'emailMessage': message})
return
props = {
'emailFormat': 'plain' (or 'html')
plugin.executeAction("sendEmail", deviceId=12345678, props=props)
