iCal Alarm Processor
You can also have iCal send an email, and that's where this plugin gets it's power. iCal alarm emails have information about the event in the email message - when it's taking place, it's name, and even any information typed into the “note” field of the event in iCal. This plugin will monitor an IMAP email address, watching for these specially-formatted emails. When it finds one, it can do various things for you, which we will cover below.
iCal Configuration Window Image
Execute a Group Group::1282734394
Execute a Trigger skipping Conditions Trigger::982343093::False
Execute a Schedule evaluating Conditions Schedule::982343093::True
Each directive should be on its own line. The first word is what kind of object should be executed (Trigger, Schedule, Action Group). Then a double colon “::” separates the ID of the object. Finally, for Triggers and Schedules, another double colon followed by “True” to evaluate conditions or “False” to ignore conditions.
That's pretty much the function of this plugin. If you want to force the plugin to check for alerts between its normal polling period, you can select “Check for Alarms” on the iCal Alarm Processor menu and it will immediately check and process any email.
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/plugins/icalalarmprocessor.txt
