NOAA Weather
NOAA Trigger States Image
  • Observation Date/Time - The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. “Fri, 19 Aug 2011 11:51:00 -0500”) so it can be parsed by other software if needed.
  • Current Condition Icon - The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA)
  • Relative Humidity - The relative humidity
  • Latitude - Latitude
  • Longitude - Longitude
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/plugins/noaaweather.txt
