The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Require authenticationcheckbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable anywhere secure accesscheckbox. - Press the
Activate Reflectorbutton.
Indigo 2021.1→Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
