Actions
In the IOM, all actions are derived from a common Action base class. This base contains all the shared components of actions. Unlike the other major classes, however, there isn't a command namespace for Actions. Why is that, you say? Because Actions don't exist outside of the object that contains them (Triggers, Schedules, Action Groups, etc.). So, when manipulating actions, you always work directly on the object, then assign that object to one of the container objects. Don't worry, we'll walk you through it.
Action Base Class
PropertyTypeDescription
Complementary Delays
Complementary Actions
Action Complement
DeviceAction
kDeviceAction.TurnOff
kDeviceAction.TurnOn
kDeviceAction.Toggle
kDeviceAction.Lock
kDeviceAction.Unlock
DeviceAction
kDeviceAction.Lock
DisableScheduleAction EnableScheduleAction
DisableTriggerAction EnableTriggerAction
EnableScheduleAction DisableScheduleAction
EnableTriggerAction DisableTriggerAction
DeviceAction (API v2.0+ only)
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action) - see Complemetary Delays for details
deviceAction kDeviceAction this is the command to send to the device
actionValue integer or dict if deviceAction is in [Brighten, Dim, SetBrightness] then this is an integer value
Device Action Enumeration
indigo.kDeviceAction
Value Description
AllLightsOffturn off all dimmer (light) devices
AllLightsOnturn on all dimmer (light) devices
AllOffturn off all dimmer (light) and relay (appliance) devices
BrightenBybrighten a dimmer (light) device by the amount specified in the actionValue integer property
DimBydim a dimmer (light) device by the amount specified in the actionValue integer property
SetBrightnessset a dimmer (light) device to the brightness specified in the actionValue integer property
SetColorLevelsset the color (RGB) and white levels to the values specified in the actionValue dict property
Toggletoggle the on/off state of a dimmer (light) or relay (appliance) device
TurnOffturn off a dimmer (light) or relay (appliance) device
TurnOnturn on a dimmer (light) or relay (appliance) device
Locklock a deadbolt or door device
Unlockunlock a deadbolt or door device
EmailAction
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableScheduleAction - see Complementary Delays for details
EnableTriggerEventAction
ExecuteGroupAction
ExecuteScriptAction
InputOutputAction
index integer if action is TurnOffOutput, TurnOnOutput, the index of the input or output to control
indigo.kIOAction
Value Description
TurnOffOutputturn off the output specified by index
TurnOffAllOutputsturn off all outputs
TurnOnOutputturn on the output specified by index
RequestStatusAllrequest status of all hardware input/outputs
RequestAnalogInputValuesrequest all analog input values from the device
RequestBinaryInputsStatusrequest all binary input statuses
RequestBinaryOutputsStatusrequest all binary output statuses
RequestSensorInputValuesrequest all sensor input values
ModifyVariableAction
Variable Action Enumeration
indigo.kVariableAction
Value Description
DecrementValuedecrement the variable value by 1
IncrementValueincrement the variable value by 1
SetValueset the variable to the variableValue property
PluginAction
SendInsteonGroupCommandAction
group integer this is the group number to send command to
indigo.kIOAction
ValueDescription
InstantOffsend the instant (fast) off command to group ignoring ramp rate
InstantOnsend the instant (fast) on command to group ignoring ramp rate
Offsend the off command to group
Onsend the on command to group
SprinklerAction
multiplierVarId integer API v1.20+ only: optional elem ID for the variable multiplier (None if no multiplier is specified)
zoneDurations list of float list of floats that represent the durations in minutes for each zone to schedule - used when sprinklerAction is RunNewSchedule
zoneIndex integer the zone to turn on as a 1-based index – used when sprinklerAction is ZoneOn
Sprinkler Action Enumeration
indigo.kSprinklerAction
Value Description
RunNewSchedulerun a new sprinkler schedule
RunPreviousSchedulerun the last executed sprinkler schedule
PauseSchedulepause the current sprinkler schedule
ResumeScheduleresume the current sprinkler schedule
StopSchedulestop the current sprinkler schedule
PreviousZoneset sprinkler to the previous zone
NextZoneset sprinkler to the next zone
ZoneOnturn on a single zone
AllZonesOffturn off all zones
RequestStatusAllrequest status of all valves
ResetInterfacesAction
ThermostatAction
actionMode kFanMode
OR
kHvacMode
if action is SetFanMode, then a kFanMode enumeration
if action is SetHvacMode, then a kHvacMode enumeration
actionValue float if action is Decrease* or Increase*, the amount to increase/decrease the setpoints
if action is Set*, the temperature to set the setpoint to
Thermostat Action Enumeration
indigo.kThermostatAction
Value Description
DecreaseCoolSetpointdecrease setpoint by value
DecreaseHeatSetpointdecrease setpoint by value
IncreaseCoolSetpointincrease setpoint by value
IncreaseHeatSetpointincrease setpoint by value
SetCoolSetpointset the setpoint to value
SetFanModeset the fan mode to mode
SetHeatSetpointset the setpoint to value
SetHvacModeset the hvac mode to mode
RequestStatusAllrequest all current values from the thermostat
RequestModerequest the current mode of the thermostat
RequestEquipmentStaterequest the current operational state of the compressor, furnace, etc.
RequestTemperaturesrequest all current temperatures from the thermostat
RequestHumiditiesrequest all current humidities from the thermostat
RequestDeadbandsrequest the current deadband ranges from the thermostat
RequestSetpointsrequest all current setpoints from the thermostat
UniversalAction (API v2.0+ only)
API v2.0+ only: This class represents a univeral action that can be used with devices of different classes. Previously this class was named GeneralDeviceAction – it was renamed in API v2.0.
deviceAction kUniversalAction this is the command to send to the device
indigo.kUniversalAction
Value Description
Beeprequest that the device perform an audible beep or buzz
EnergyUpdaterequest that the energy meter send its most recent meter data
EnergyResetrequest that the energy meter reset its accumulative energy usage data
RequestStatussend a device a status request for a complete update
indigo_2021.1_documentation/action_class.txt · Last modified: 2021/04/21 18:57 (external edit)
