in this location:
/Library/Application Support/Perceptive Automation/Indigo 7(.X)
and Plugins (Disabled)
folder.
PluginVersion
- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.ServerApiVersion
- this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.CFBundleDisplayName
) - this is a standard macOS key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.CFBundleName
) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.CFBundleIdentifier
) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.yourorgidentifier.*
) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required.CFBundleURLTypes
) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's Github repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.We want the user experience to be very similar for plugins, at least until it comes to configuration and use of the plugin, so you should be careful to get the Info.plist correct.
file in here, it will be displayed in the Plugin Store once you submit
, Action
, Device
, type
, defaultValue
id
's can contain letters, numbers, and other ASCII charactersid
's cannot start with a number or punctuation characterid
's cannot start with the letters xml (or XML, or Xml, etc)id
's cannot contain spaces
, Events
, Actions
, and the PluginConfig
file.
attribute is required for every field and must be unique within the dialog - it’s used to establish enabled and visible bindings between fields and more importantly it’s the key used in the dictionary to get the values when you get messages from the dialog (discussed more later). The id
must be alphanumeric (and may contain underscores) and must begin with an alphabetic character.
attribute. The value
element and a List
elements. Each Option
element must have a value
As with menu
The indigo.devices
class specifies that the list will contain Indigo devices. If you don’t specify a filter, all devices defined by the user in Indigo will be returned. You can supply two filters if and only if one is an interface filter (see the first two in the list below). The filters are ANDed together, so one interface filter and one device type filter are the only combinations that will result in a non-empty list.
Class: indigo.devices |
The indigo.triggers
Class: indigo.triggers |
Using the indigo.schedules
and indigo.controlPages
The valuesDict
The typeId
, Network Socket
, or Network RFC-2217
Aside from the standard Label
The process flow is this:
<CallbackMethod>
element.
XML for a device like this:
method.
False
, Events
, and Actions
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/Plugins/
in the Info.plist
type | Attribute | Yes | This must be one of: relay , dimmer , thermostat , sensor , speedcontrol , or custom . We’ll discuss each below. |
The custom
, String
, List
(enumeration), Boolean
defined in the <Device>
As you can see, your <Event>
element as well - the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
elements:
As with <Event>
, your <Action>
element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all actions will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements:
<Action id="sep1"/>
elements:
deviceFilter | Attribute | No | If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod . This will avoid the necessity to create a ConfigUI element with just a device popup. |
%%v:12345%%
into their string where 12345
%%d:12345:someStateId%%
In API v1.x
General Plugin Methods | ||
You'll most likely use the |
Note: |
You must call |
Device Specific Methods | ||
deviceCreated(self, dev) | Deprecated in 1.4 | This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead. |
Trigger Specific Methods | ||
Name | Required | Notes |
and <Actions>
, errorLog()
, and exceptionLog()
. These were shortcuts which showed varying levels of log information in the Indigo Event Log window. In API 2.0, we've deprecated those methods in favor of the standard Python logging module (don't worry though, the previous APIs will continue to work).
Attribute | Description |
The logger module defines 5 levels of logging: logging.DEBUG
, logging.INFO
, logging.WARNING
, logging.ERROR
, logging.CRITICAL
. Instances of the Logger object can be set to log messages at any of those 5 levels, and the level logged can be changed at any time. By default, the self.logger
The debugLog()
, errorLog()
and self.plugin_file_handler
, self.logger.info
The self.indigo_log_handler
is an instance of a custom Handler object that will write (or emit in Python Handler speak) your log messages into the Indigo Event Log. We haven't yet updated the Indigo event handling to deal with 5 levels of log messages, so each the message type (the left part in the Event Log) is modified so that it reflects the level. Here's an example of each:
The last two, being errors, are in red in the actual Event Log window. In a future release, we hope to change the server's internal logging to use these same 5 log levels. When we do so, you won't have to do anything - we'll just update the self.indigo_log_handler
instance to emit the appropriate messages to the server.
The self.plugin_file_handler
. Does this mean that all debug or better messages are automatically sent to both the file and the Indigo Event Log? Actually, no. The reason is because you can also specify at the handler what level to actually log. We default the plugin_file_handler to logger.DEBUG
but we default the indigo_log_handler to logger.INFO
set to True
to logger.DEBUG
. And if it's False, we set it to logger.INFO
Logging from a submodule is relatively straight-forward. You can either get the logger for the plugin:
and use it directly, or you can pass your logger into the methods of the submodule. You could also pass in the event log handler defined for you by the plugin base (self.indigo_log_handler
), and then attach that to a custom logger in your module.
If you use the instance of self.indigo_log_handler
, the message emitted to the Event Log window will have a type that is the name of the plugin.
If you want log lines with titles other than the plugin name (like a name specific to the submodule), you can instantiate an instance of the IndigoLogHandler
class (which is what self.indigo_log_handler
is) instead:
custom_logger = logging.getLogger("MyModule") custom_handler = self.IndigoLogHandler("MyModule", logging.DEBUG) custom_logger.addHandler(custom_handler)
And anything logged to your plugin_logger
will be reflected in the Event Log:
<Action id="handle_message" uiPath="hidden"> <Name>some message</Name> <CallbackMethod>handle_some_action</CallbackMethod> </Action>
def handle_some_action(self, action, dev=None, callerWaitingForResult=None): some_value = action.props["somekey"] return some_value
Calls via this method will always pass in callerWaitingForResult=True
. You will want to make sure that your plugin returns as quickly as possible - any long-running processes should be put into another thread with some sort of asynchronous message back to the caller if necessary.
IWS will insert several things into the action.props
dictionary:
Key | Value |
Key | Value |
Status | Meaning |
For 50x
errors, a JSON dictionary will be returned describing the issue:
Key | Value |
error | One of: plugin_disabled , invalid_plugin , invalid_action , unknown_error |
This API is meant primarily for small(ish) text message handling, like JSON/XML messaging APIs. There are a few things that you will want to avoid:
