Substitutions
%%v:VARID%%
%%d:DEVID:STATEID%%
The current album playins is %%d:123456:album%%.
indigo_2021.1_documentation/plugins/variable_substitution.txt · Last modified: 2021/04/21 18:57 (external edit)
