Indigo Server Plugin Tutorial
Note most of the code examples below are calling methods on the object self. In this context, self is meant to be the Plugin instance as defined inside the plugin.py file. To execute the sample code outside Plugin instance methods use the indigo.activePlugin object instead.
Important: For simplicity some of the samples below specify objects based on name (“office desk lamp”). However, the preferred lookup mechanism is to use the object's ID which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the ID you ensure the object will be found even if its name is changed.
| Plugin task | Plugin that illustrates an approach |
| Parsing XML from an IP source | NOAA Weather, WeatherSnoop |
| Integrating with native Mac Apps | Airfoil |
| Sending RS232 (serial port & network serial port) Commands | EasyDAQ |
| Reading RS232 (serial & network serial port) Input | EasyDAQ |
| Interacting with an IMAP mail server | iCal Alarm Processor |
| Creating custom devices with states | Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ, iTunes |
| Creating custom actions | Growl, Action Collection |
| Creating custom events | Airfoil |
Each of these plugins is installed by default with Indigo - in the /Library/Application Support/Perceptive Automation/Indigo [VERSION]/Plugins (Disabled)/ folder. To see the various XML and python source files, just right-click on it in the Finder and select Show Package Contents.
- Per plugin prefs file is automatically managed (created, loaded, updated).
- Key values defined in PluginConfig.xml are automatically mapped into the plugin's prefs space which is available via:
self.pluginPrefs.get("somePrefKey", "default value if key doesn't exist")The latter will return the second parameter if they key doesn't exist in the dictionary - it's your responsibility to add it to the prefs dict if you want it to be stored permanently.
- Plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin's config UI).
- To read a preference value access its key:
someVal = self.pluginPrefs["somePrefKey"] indigo.server.log("value is " + str(someVal)) - To create a new or update an existing preference value assign it a new value:
.pluginProps. - The pluginProps dictionary supports numbers, boolean, strings, indigo.Dict() or indigo.List().
- Example adding new plugin metadata to the Device “den fixture”:
dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] = 5 newProps["moreData1"] = "abc" newProps["moreData2"] = True newProps["moreData3"] = 123.45 dev.replacePluginPropsOnServer(newProps)
- Example reading the plugin specific property onCycles from the Device “den fixture”:
dev = indigo.devices["den fixture"] onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is " + str(onCycles)) - Example incrementing by 1 the plugin specific property onCycles for the Device “den fixture”:
dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] += 1 dev.replacePluginPropsOnServer(newProps) dev = indigo.devices["den fixture"] onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is now " + str(onCycles)) - Plugins have read-only access to other plugin metadata via
.globalProps. - Plugins have read/write access to their own metadata space.
Creating a Custom Plugin Device
- Properties define the user configurable options for a device instance, and are specified in the
<ConfigUI>XML node. Every fieldidis automatically mapped into the device instance.pluginPropsmetadata dictionary (described above) as a unique key. - States are specified in the Devices.xml
<States>XML node, and are used to define the transient state information for a device (ex: on/off setting, brightness, temperature, etc.). - States defined in Devices.xml are automatically shown in the Trigger Event
Device State Changedoptions when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device. - States are read-only for everyone except the plugin that defines the device's states.
- Plugins should update a device state after it has sent commands to hardware, or somehow received new state information from hardware. Example that increments the plugin defined state
heatSetPointby 1:dev = indigo.devices["Custom Plugin Thermostat"] dev.updateStateOnServer("heatSetPoint", dev.states["heatSetPoint"] + 1) - Plugins should subclass
deviceStartCommanddeviceStopCommto start/stop any hardware communication (normally via a new per-device thread):def deviceStartComm(self, dev): self.easydaq.startCommThread(dev) def deviceStopComm(self, dev): self.easydaq.stopCommThread(dev)
- Calls to
deviceStartCommanddeviceStopCommare automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receivedeviceStartCommcalls. Likewise,deviceStartCommis called when a new plugin device is created or duplicated.deviceStopCommis called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
Creating a Custom Plugin Trigger Event
Explain Events.xml. Show example plugin subclasses of functions: triggerStartProcessing, triggerStopProcessing, didTriggerProcessingPropertyChange. Note it works very similarly to devices.
Monitoring Device State Changes from a Plugin
Give examples of using indigo.devices.subscribeToChanges() and plugin subclasses of functions: deviceDeleted, deviceUpdated.
Monitoring Changes to Variables, Triggered & Scheduled Events, Action Groups, and Control Pages
Give examples of using indigo.*.subscribeToChanges() and plugin subclasses of functions: variableCreated, variableDeleted, variableUpdated, triggerCreated, triggerDeleted, triggerUpdated, scheduleCreated, scheduleDeleted, scheduleUpdated, actionGroupCreated, actionGroupDeleted, actionGroupUpdated, controlPageCreated, controlPageDeleted, controlPageUpdated.
