Indigo Scripting Tutorial
Talking to the Indigo Server
Note: you'll want to read through the introduction section of the Indigo Object Model, it gives you some fundamental information that you need to successfully script Indigo.
Example Code Snippets
Device Examples
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
from datetime import datetime
Access a custom device state
Variable Examples
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import urllib, urllib2
myUnicodeString = u"éçø"
myInteger = 1
myFloat = 1.0
import simplejson as json
myNewDictionary["myList"]
class myCustomClass:
def __init__(self):
self.a=1
self.b=2
def __unicode__(self):
return outputString
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Log Examples
Log to the Indigo Event Log window using different levels of loging
import logging
Folder Examples
except ValueError, e:
myFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Connecting Remotely over SSH
What Else Can it Do?
indigo-host -e '
Executing Indigo Python Files
Executing AppleScript
indigo_attachments.py
import indigo
except ImportError:
raise ImportError
def log(message, label=None):
import indigo_attachments
raise ImportError
ImportError
Scripting Indigo Plugins
pluginSupportURL | str | The URL supplied by the plugin that points to its user documentation |
storePluginURL | str | The description of the plugin in the plugin store (None if the plugin isn't in the plugin store) |
| Method | Description |
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
Restart a Plugin
