Email+
Email Devices and Usage
You will need to confirm your settings with your email provider. We highly recommend using a dedicated email address for Indigo, particularly if you are performing email scans.
Sending an Email
In the Actions tab, you can use the Notification Actions→Send Email action to send an email:
The format can be either plain text or HTML (it is your responsibility to ensure that the Message field contains a valid HTML document - we don't attempt to validate it). Variable (%%v:VariableIDHere%%) and device state (%%d:DeviceIDHere:StateIDHere%%) substitutions are available in all fields, and you can specify attachments by entering the full path to a file, each file separated by commas.
Sending Event Log Data
In the Actions tab, you can use the Email+ Actions→Send Indigo Log Email action to send parts of your Event Log lines:
Email Queue Management Menu Items
You can use the Plugins→Email+→Clear All Email Queues to clear out all queued emails from all of your SMTP servers. If your email server is having issues, you may find that you want to clear out all pending emails that the plugin has queued up for your email server.
You can use the Plugins→Email+→Clear Email Queue… to clear out the email queue for a specific SMTP server.
Receiving Emails
IMAP Server
Leave in INBOX(default) - this is the safest option if you are using this email address for other things. It can lead to an ever growing email list, so you'll need to delete messages yourself once you're sure you are done with them.Delete Message- if you are using a dedicated email address for Indigo, this is a good option since it will delete a message after it's been processed. This will keep the inbox from growing uncontrollably.Move Message- this is a compromise of the two options above: it keeps the INBOX clean but it also keeps all emails if you want to manually manage them.
IMAP Mailbox Naming
- Processed
- INBOX/Processed
- INBOX.Processed
POP Server
Incoming Email Events
String Match in Email- this event will allow you to perform exact matches in the subject or body of an email, or the sender of the email.RegEx Pattern Match in Email- this will allow you to use regular expressions to match some subset of text in the above 3 fields.Server Connection Error- this will fire a trigger when there is some kind of error in any of the 3 server types above.
Broadcast Messages
MessageType: messageReceived
Returns dictionary:
'messageFrom': <text string>,
'messageTo': <text string>,
'messageSubject': <text string>,
'messageText': <text string>
MessageType: messageSent
Returns dictionary:
Tips on IMAP Mailbox Naming
- Processed
- INBOX/Processed
- INBOX.Processed
Scripting Emails
indigo.server.sendEmailTo("[email protected]", subject="Subject of email", body="Body of email")
plugin = indigo.server.getPlugin("com.indigodomo.email")
if plugin.isEnabled():
plugin.executeAction("sendEmail", deviceId=12345678, props={'emailTo':'[email protected]', 'emailSubject': subject, 'emailMessage': message})
return
props = {
'emailFormat': 'plain' (or 'html')
plugin.executeAction("sendEmail", deviceId=12345678, props=props)
