Music (iTunes) Plugin for Indigo
Note: As of version 1.1.5 (Big Sur), you can no longer pair and control from a different Mac. This appears to be part of Apple's tightening of security as the Music app specifically returns an error that remote login capability is not supported.
This plugin is the basic Music (iTunes) integration plugin. You may create as many “iTunes Server” devices as you have on your network (but only one per Music instance as defined by Music running on a Mac - you can't have multiple iTunes server devices that are pointing to the same iTunes instance). For each of those devices, you can trigger off of various state changes in the built-in Device State Changed trigger type and you can execute many different actions in the Actions tab. None of this requires scripting of any kind.
Indigo now includes a device state image for use with Music which mimics the Play/Pause button in iTunes. If the Music play state is “playing”, the icon will show the pause symbol and vice versa. If it's “unavailable” it will be grayed out and if there's an error it will be reddish. To use just select iTunesStatus_large+, iTunesStatus_med+, or iTunesStatus_small+ in the control page editor and you'll get automatic play/pause switching icon. Works even better when you make the action a “Toggle Play/Pause” plugin action.
Plugin Config
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes.
If you're using the Music app (macOS Catalina 10.15.2 or above) that replaced iTunes, you'll see a line in the outline view on the left under Devices named “Indigo - [YOUR DATABASE NAME HERE]”. Select that item.
If you're using iTunes 12, you'll see a button with an right arrow in it in the upper left corner of the iTunes window:
If you're using iTunes 11, you'll see a button titled Remote in the upper right corner next to the iTunes Store button:
Select Indigo Remote Control
Device States
Player Status Changed- any change to the play state of iTunesPlayer Status is Playing- iTunes is playingPlayer Status is Paused- iTunes is pausedPlayer Status is Stopped- iTunes is stoppedPlayer Status is Unavailable- iTunes is unavailable - it's probably not runningPlayer Status is Error- this iTunes device has an unknown error - look in the Event Log for details
Current Playlist Name- the current playlist that's selected in iTunesCurrent Album- the current album nameCurrent Artist- the current artist nameCurrent Track- the current track nameCurrent Volume- the current volume level
Repeating Changed- any change in repeat statusRepeating None- iTunes is not repeatingRepeating Song- iTunes is repeating the current songRepeating Playlist- iTunes is repeating the current playlistShuffling- iTunes is shuffling songs
Actions
Play- start iTunes playingPause- pause iTunesToggle Play/Pause- toggle between playing and pausedNext Track- move to the next trackPrevious Track- go back to the previous trackRestart Track- restart the current track
Pause iTunes and Say- pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.\\
Set Volume- set the volume to a specific level (0-100)Increase Volume- increase the volume by a specific amount (0-100)Decrease Volume- decrease the volume by a specific amount (0-100)
Set Repeat- set iTunes to repeat (or not)Set Shuffle- set/unset shuffling
Scripting Support
Action specific properties
Play
Action id: play
if itunesPlugin.isEnabled():
Pause
Action id: pause
Toggle Play/Pause
Action id: playPause
Next Track
Action id: nextTrack
Previous Track
Action id: prevTrack
Restart Track
Action id: restartTrack
Pause and Speak Text
Action id: pauseAndSay
Properties for scripting:
Set Volume
Action id: setVolume
Increase Volume
Action id: increaseVolume
Decrease Volume
Action id: decreaseVolume
Set Repeat
Action id: setRepeat
Set Shuffle
Action id: setShuffle
Support and Troubleshooting
