In the IOM, all devices are derived from a common Device
base class. This base class provides for all the common properties of a device (including devices defined by Server plugins) and each subclass also inherits all the commands in the device command namespace (indigo.device.*
) - there are a few exceptions that will be noted below. Check out the examples for each section to see how you use each device type.
To create, duplicate, delete, and send commands to a device, use the appropriate command namespace as defined below
To modify an device's definition get a copy of the device, make the necessary changes, then call myDevice.replaceOnServer()
To update a plugin's props on a device on the server, call myDevice.replacePluginPropsOnServer(newPropsDict)
rather than try to update them on the local device
To change a device's state on the server, use myDevice.updateStateOnServer(key='keyName', value='Value')
To change multiple device states on the server at one time, use myDevice.updateStatesOnServer(update_list)
passing a dictionary that looks like this:
key_value_list = [
>>> print(json.dumps(python_dict, indent=4, cls=indigo.utils.JSONDateEncoder))
"allowOnStateChange": false,
"protocol": "ZWave",
"configured": true,
"states": {
"onOffState": true,
"batteryLevel.ui": "100%",
"batteryLevel": 100
"subType": "",
"globalProps": {
"zwConfigVals": {},
"zwShowWakeIntervalUI": true,
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwShowDumpDevToLog": false,
"zwLibType": 3,
"SupportsBatteryLevel": true,
"zwProtoVersMajor": 4,
"zwEndpointDevTypeMap": {},
"userWakeInterval": 60,
"indigoObjVersion": 10,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"SupportsOnState": true,
"zwShowMainUI": true,
"zwAppVersMinor": 1,
"userPollInterval": 0,
"zwDevSubIndex": 0,
"zwEncryptClassCmdMap": {},
"address": 17,
"zwEndpointClassMap": {},
"zwModelDefnVers": 0,
"zwManufactureId": 0,
"SupportsSensorValue": false,
"zwAssociationsMap": {
"g1": [
1
"zwShowPollingUI": false,
"zwWakeInterval": 60,
"zwClassCmdBase": 0,
"zwAppVersMajor": 5,
"zwProtoVersMinor": 5,
"zwNodeNeighbors": [
1,
15,
16
"userPollingEnabled": true
"pluginProps": {},
"buttonGroupCount": 0,
"id": 854505717,
"supportsAllOff": false,
"errorState": "",
"remoteDisplay": true,
"energyAccumBaseTime": null,
"displayStateValUi": "on",
"subModel": "",
"version": "5.01",
"energyAccumTimeDelta": null,
"batteryLevel": 100,
"supportsSensorValue": false,
"ownerProps": {
"zwConfigVals": {},
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwLibType": 3,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"zwDevSubIndex": 0,
"address": 17,
"g1": [
1
1,
15,
16
"description": "",
"onState": true,
"energyAccumTotal": null,
"address": "17",
"sharedProps": {},
"folderId": 1145028206,
"supportsOnState": true,
"sensorValue": null,
"energyCurLevel": null,
"enabled": true,
"displayStateValRaw": true,
This will be a python dictionary with all details about a device. One other feature to note here: by default, Python datetime
objects are not serializable by the json
module (odd oversight we believe). We have included a JSON encoder class that will solve this problem: indigo.utils.JSONEncoder
. Just specify that as the cls
parameter to a json dump call and any datetime class that's encountered during JSON encoding will be correctly converted to a string in the resulting json string:
Device Base Class
The Device
class is generally used as a base class - your script will use objects that are instances of one of it’s subclasses - we'll discuss each of the subclasses later in this section. First, a quick refresher on a fundamental aspect of devices: some devices can only be controlled (i.e. old-style ApplianceLincs, most X10 devices, etc.), called responders in Indigo terminology, other devices are only controllers (i.e. RemoteLincs, PalmPads, etc.), and some devices are both responders and controllers (i.e. KeypadLincs).
Device Base Class Properties
Property | Type | Writable | Min API | Description |
energyAccumBaseTime | datetime | No | 1.11 | the base time from which to calculate the energy total (energyAccumTotal ) (None if not supported) |
globalProps | dictionary | No | 1.0 | an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have it's own dictionary (globalProps[pluginId] ) - see About Plugin Properties below for details |
pluginId | string | No | 1.0 | if protocol is Plugin , the string ID for the plugin |
sharedProps | dictionary | No | 2.3 | an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Protocol Enumeration
indigo.kProtocol |
Value | Description |
State Image Sel Enumeration
API v1.18+ only:
indigo.kStateImageSel |
Method | Restricted | Min API | Description |
stateListOrDisplayStateIdChanged() | Yes | 1.0 | Plugins can subclass the method getDeviceStateList() to provide dynamic state list definition information. The default implementation provides a static solution by retrieving the device state list definition from the Devices.xml file. Likewise, the method getDeviceDisplayStateId() can be used to dynamically determine which device state should be displayed in the State column of the main device table UI. The problem is that the Indigo Server only calls getDeviceStateList() and getDeviceDisplayStateId() at very specific times, like when a plugin device dialog is dismissed. So, call stateListOrDisplayStateIdChanged() on the device instance you need refreshed at any time and Indigo will then automatically call your plugin's getDeviceStateList() and getDeviceDisplayStateId() methods (or use the base implementation of looking up the list from Devices.xml) and update the Indigo Server (and all clients). This is particularly useful for plugin updates that need to add new device states to existing device instances created by older versions. In this case, the plugin will need to update the device instances by calling stateListOrDisplayStateIdChanged() . A likely place to do this type of instance level upgrading is inside your plugin's deviceStartComm() method. |
updateStateImageOnServer(stateImageSel) | Yes | 1.18 | Use this method to override which device state image icon is shown for this device on Indigo Touch and the Indgo client UI. The default behavior is for Indigo Server to automatically determine which icon should be shown based on the device class and state value. Only call this method if overriding the default behavior is needed. |
Devices have properties - some are class properties, defined by the class itself. One of the biggest requests we've gotten in the past is some way to add arbitrary properties to a device - so that you could store your own data with the device in the database. And with plugin defined devices, we needed a place to store the properties that you need to operate the device. That's what the pluginProps
and globalProps
is a dictionary of every additional property defined for the device - each plugin has it's own dictionary of props in here which are readable by anyone. pluginProps
is a shortcut to get to your plugin's props and are only writable by your plugin once the plugin has been created - a script can create a device supplied by your plugin along with the necessary properties, which are passed in on the create()
method. You should publish the properties necessary to make your device work so that scripters can create your devices.
dev=indigo.devices[123]
defined for the device, those properties are also stored here - so in order to make sure your device works correctly you must include those properties as well. If you need to update several properties in your props dict, you can use the update()
method:
The update()
method will change the properties specified, and add the property if it doesn't exist. Now, you might be wondering - why do the extra localPropsCopy = dev.pluginProps
Because the dev object is read-only - when you reference dev.pluginProps
, it returns a copy rather than returning a reference to the read-only object. So, in effect, you'd be modifying a copy. But, because you aren't saving a reference to that copy, it goes away since the next time you reference dev.pluginProps
another copy is made.
About Custom Device States
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
It's actually pretty simple. When your plugin detects a change in one of the states, you just call the updateStateOnServer('id', value='value')
method. Here are some examples for setting the state based on the above state definitions:
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Note - for states that have a <ValueType>
of Number
, you pass an integer or float; for states that are Boolean
, you pass Python True
or False
; all others pass a string.
It's just that simple. This will cause any triggers on the server that are set on your device's states to be fired. It will update any visible control pages. It will show the state that's defined in the <UiDisplayStateId>
element in the Mac device table's State
column.
The updateStateOnServer
method has 3 optional parameters: decimalPlaces
(integer), triggerEvents
(boolean), and uiValue
(string, API v1.6+ only).
When updating floating point state values use the decimalPlaces
parameter to specify the number of fractional digits to store and display. For example:
The triggerEvents
parameter can be set to False (defaults to True) to have the Indigo Server update the state but ignore any Device State Changed triggers that should be processed as a result of the state change.
And the optional uiValue
parameter is used to set UI only display string of the value which is not used in triggers or conditional logic. This is useful for adding units, percent signs, etc:
Commands (indigo.device.*)
All Off
Command Syntax Examples |
indigo.device.allOff()
Parameters |
direct parameter | Yes | kAllDeviceSel | enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
indigo.kAllDeviceSel |
Enumerated Type | Description |
Beep (API v1.11+ only)
indigo.device.beep(123)
Parameters |
direct parameter | Yes | integer | id or instance of the device |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices ( you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address='F8',
name='Device Name Here',
folder=1234)
Parameters |
protocol | Yes | kProtocol | the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10 ) |
indigo.device.delete(123)
Parameters |
direct parameter | Yes | integer | id or instance of the device to delete |
Parameters |
direct parameter | Yes | integer | id or instance of the device to duplicate |
Enable/Disable
Parameters |
direct parameter | Yes | integer | id or instance of the device to enable/disable |
Get Group List
Parameters |
direct parameter | Yes | integer | id or instance of any device that belongs to a device group. |
Parameters |
direct parameter | Yes | integer | id or instance of the device to get the dependencies for. |
ID : 1280166770 (integer)
ID : 106487666 (integer)
Parameters |
Ping Device (API v1.16+ only)
API v1.16+ only: Sends the Z-Wave or INSTEON module a ping command and measures the round trip ACK time. Returns a dict containing the Success
and TimeDelta
(milliseconds) result.
if result["Success"]:
Parameters |
suppressLogging | No | boolean | True to keep the request from being logged into the event log window (default is False ) |
Parameters |
direct parameter | No | integer | id or instance of the device |
API v1.11+ only: Resets the energyAccumTotal
and energyAccumTimeDelta
values and changes the energyAccumBaseTime
to the server's current datetime.
Parameters |
Parameters |
Status Request
Parameters |
direct parameter | Yes | integer | the id of the device |
Toggle
indigo.device.toggle(123)
Parameters |
Turn Off
indigo.device.turnOff(123)
Parameters |
Turn On
indigo.device.turnOn(123)
Parameters |
Unlock (API v2.0+ only)
API v2.0+ only: This tells IndigoServer to unlock a device. This command only works for relay device types that have pluginProps[“IsLockSubType”]
set to True.
indigo.device.unlock(123)
Parameters |
Lock (API v2.0+ only)
API v2.0+ only: This tells IndigoServer to lock a device. This command only works for relay device types that have the property pluginProps[“IsLockSubType”]
set to True.
indigo.device.lock(123)
Parameters |
# Creating a device
name="Office Lamp",
address="F7",
# Getting a device
-- Getting a device
if (myDevice.remoteDisplay):
all off
DimmerDevice
Device States
These are the states provided by this device type and accessible through the dev.states dictionary. They are read-only, but if you're a plugin developer you can use the updateStateOnServer()
class method to update the value for devices owned by your plugin.
State ID | Type | Property Name | Notes |
onOffState | boolean | onState | indicates whether the device is on - can be accessed by dev.onState . |
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
Parameters |
direct parameter | No | kAllDeviceSel | enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
All Lights On
indigo.dimmer.allLightsOn()
Parameters |
direct parameter | No | kAllDeviceSel | enumerated value to indicate which lights to turn on, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
Brighten
indigo.dimmer.brighten(123)
Parameters |
Dim
indigo.dimmer.dim(123)
Parameters |
Set Brightness
Parameters |
Set LED State
Parameters |
Set On State
# Getting a device
(myDevice.onState)):
myDevice.folderId
# OR
That code works correctly, but is very inefficient. The Python to C++ bridge will cause a copy of the object to be made every time indigo.devices[123]
is used since the devices list is a C++ object, but the object returned from it using the id subscript is bridged to a Python object, and all bridged objects are copies. So, the code directly above will create 3 copies of the device object - very inefficient. The code in the example above gets a single copy of the object and uses that in all the rest of the code. A good rule of thumb is to get an explicit copy of an object if you need to use it more than once.
Device States
dictionary. They are read-only.
analogInput# | integer | N/A | value of input number represented by the # sign (input 1 would be analogInput1 ) - there will only be dev.analogInputCount inputs available |
analogInputsAll | string | N/A | a comma separated list of all analog input values. Can be accessed as a Python list of integers by using dev.analogInputs . |
binaryInput# | boolean | N/A | value of input number represented by the # sign (input 1 would be binaryInput1 ) - there will only be dev.binaryInputCount inputs available |
binaryInputsAll | string | N/A | a comma separated list of all binary input values. Can be accessed as a Python list of booleans by using dev.binaryInputs . |
binaryOutput# | boolean | N/A | value of output number represented by the # sign (output 1 would be binaryOutput1 ) - there will only be dev.binaryOutputCount outputs available |
binaryOutputsAll | string | N/A | a comma separated list of all binary output values. Can be accessed as a Python list of booleans by using dev.binaryOutputs . |
sensorInput# | integer | N/A | value of input number represented by the # sign (input 1 would be sensorInput1 ) - there will only be dev.sensorInputCount inputs available |
sensorInputsAll | string | N/A | a comma separated list of all binary input values. Can be accessed as a Python list of booleans by using dev.sensorInputs . |
Commands (indigo.iodevice.*)
Set Binary Output
Parameters |
X10 Motion Sensors
the Wireless INSTEON Motion / Occupancy Sensor (2420M) from SmartLabs
the TriggerLinc from SmartLabs
the SynchroLinc from SmartLabs
Commands (indigo.sensor.*)
Set On State
Parameters |
value | Yes | boolean | True to set Indigo’s state to on, False to set it to off |
RelayDevice
Property | Type | Description | |
Device States
Commands (indigo.relay.*)
Set LED State
Parameters |
# Toggle the device
SpeedControlDevice
Device States
Decrease Speed Index
Decreases the speed index.
Parameters |
Increase Speed Index
Increases the speed index.
Parameters |
Set Speed Index
Parameters |
Set Speed Level
Parameters |
SprinklerDevice
zoneEnableList | list of boolean | No | 1.13 | list of booleans, starting at zone 1 through zone [zoneCount ], that specify if a given zone is enabled (has a maximum zone duration > 0). |
zoneNames | list of string | No | 1.0 | list of zone names, starting at zone 1 through zone [zoneCount ]. You must include zoneCount strings in the list. |
zoneMaxDurations | list of floats | No | 1.0 | list of zone durations in minutes, starting at zone 1 through zone [zoneCount ]. You must include zoneCount integers in the list. |
zoneScheduledDurations | list of floats | No | 1.0 | list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [zoneCount ] |
Device States
zone# | boolean | N/A | replace the # with the zone number (up to dev.zoneCount ) to return whether the zone is running or not |
Commands (indigo.sprinkler.*)
Next Zone
Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
Parameters |
Previous Zone
Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
Parameters |
Run Schedule
Run a sprinkler schedule.
Parameters |
schedule | Yes | list of reals | list of reals representing the number of minutes to run for each zone - the list must have [zoneCount ] elements, with 0 for any zone that shouldn’t run |
Stop Schedule
indigo.sprinkler.stop(123)
Parameters |
Set Active Zone
Parameters |
# run schedule
ThermostatDevice
Thermostats have a wide variety of capabilities that we’ve tried to boil down to some specifics. They can have multiple temperature and humidity sensors, they generally have a fan mode, an HVAC mode (heating, cooling, etc) and associated setpoints. Note: some thermostats don’t support getting the equipment state values: coolIsOn
, fanIsOn
, heatIsOn
, dehumidifierIsOn
, and humidifierIsOn
. For those thermostats those properties will always be False.
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Device States
class method to update most of these states for devices owned by your plugin (exceptions are noted below).
humidityInput# | float | N/A | replace the # with the humidity sensor # (up to humiditySensorCount ) to directly access the humidity value for that input |
hvacFanIsAlwaysOn | boolean | N/A | True if the fan mode is set to AlwaysOn . Note: this state can't be directly updated but rather will be updated automatically when you update hvacFanMode . |
hvacFanIsAuto | boolean | N/A | True if the fan mode is set to Auto . Note: this state can't be directly updated but rather will be updated automatically when you update hvacFanMode . |
hvacOperationModeIsAuto | boolean | N/A | True if the HVAC is set to HeatCool . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsCool | boolean | N/A | True if the HVAC is set to Cool . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsHeat | boolean | N/A | True if the HVAC is set to Heat . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsOff | boolean | N/A | True if the HVAC is set to Off . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsProgramAuto | boolean | N/A | True if the HVAC is set to ProgramHeatCool . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsProgramCool | boolean | N/A | True if the HVAC is set to ProgramCool . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
hvacOperationModeIsProgramHeat | boolean | N/A | True if the HVAC is set to ProgramHeat . Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode . |
temperatureInput# | float | N/A | replace the # with the temperature sensor # (up to temperatureSensorCount ) to directly access the humidity value for that input |
Decrease Cool Setpoint
Parameters |
value | Yes | integer | number of degrees to decrease the cool setpoint |
Decrease Heat Setpoint
Parameters |
Increase Cool Setpoint
Parameters |
Increase Heat Setpoint
Parameters |
Set Cool Setpoint
Parameters |
Set Fan Mode
Adjust the fan mode.
Parameters |
Set Heat Setpoint
Parameters |
Set HVAC Mode
Adjust the HVAC mode.
Parameters |
# set the heat setpoint to 78
