Folders
Commands (indigo.*.folder.*)
Delete the specified folder.
Get ID
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
indigo_2021.2_documentation/folder_class.txt · Last modified: 2022/04/30 22:09 by mattb
