To make a device available to Alexa, you must explicitly publish it. Use thePlugins→Alexa→Manage Device Publications…
menu item to open the publication dialog:
We will take a guess at what the specific type of the device is, but we won't always guess correctly. For instance, if there isn't anything about your device that Indigo can determine, it will just automatically select Switch
. You can override that setting however to make the device best match what it does.
The options are:
Shades of White | Temperature in Kelvin |
warm, warm white | 2200 |
incandescent, soft white | 2700 |
white | 4000 |
daylight, daylight white | 5500 |
cool, cool white | 7000 |
We will take a guess at what the specific type of the device is, but we won't always guess correctly. For instance, if there isn't anything about your device that Indigo can determine, it will just automatically select Dimmer
The options are:
Blind
- use this type if your dimmer device actually controls blinds, shades, or drapes. You can say things like: Fan
- use this type if your device actually controls a fan (as of this release Z-Wave fan controllers are treated as dimmers in Indigo). Fan devices from Indigo in Alexa will support 4 modes: Off, Low, Medium, High. You can say things like:Valve
- use this type if your device controls a valve, or really any device that has a 0-100% range. You can say things like:Indigo has a native fan device type. Currently, the only built-in device using this type is the Insteon FanLinc. There are some other plugins which also support this device type. If you select a device of this type the only option will be the Alternative name as there are no other options. You can say things like:
<speak></speak>
tags.You can hear a list of your variables as well. Here are a variety of ways to ask:
Started plugin "Alexa 2021.2.0" Alexa Finding devices to publish to Alexa... Alexa ... '010 - Smart Fan Control (14287)' published as 'office fan' Alexa ... '016 - Plug-In Appliance Module (ZL-PA-100)' published as 'office lamp' Alexa ... '038 - Lamp Module (AD130)' published as 'blinds' Alexa ... 'automatic door' published Alexa ... 'FanLinc - Fan' published as 'ceiling fan' Alexa ... 'FanLinc - Light' published as 'fan light' Alexa ... 'Fortrezz Strobe' published as 'strobe' Alexa ... 'Hue Bulb' published as 'office bulb' Alexa ... 'Insteon Dimmer' published as 'valve' Alexa ... 'Insteon On/Off' published as 'back door' Alexa ... 'Insteon Thermostat' published as 'thermostat' Alexa ... 'Kasa Plug' published as 'garage door' Alexa ... 'Office Siren' published Alexa ... 'outlet' published Alexa ... 'Simple Virtual On/Off' published as 'simple switch' Alexa A total of 15 devices are currently published to Alexa Alexa Warning If you can't control a device, rerun discover from your Alexa device.
You can also select the Plugins→Alexa→Show Device Publications
menu item to show this list with more details and sorted by the Alexa name:
Alexa Currently published devices (Alexa name first if different than Indigo name): Alexa 'Office Siren' ('Office Siren') - Type: RelayDevice - Subtype: Siren Alexa 'automatic door' ('automatic door') - Type: RelayDevice - Subtype: Door Controller Alexa 'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa 'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa 'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa 'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa 'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa 'office bulb' ('Hue Bulb') - Type: DimmerDevice - Subtype: Color Bulb Alexa 'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa 'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa 'outlet' ('outlet') - Type: RelayDevice - Subtype: Outlet Alexa 'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa 'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa 'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa 'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Alexa Alexa discovery request received, assembling reply... Alexa ...'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa ...'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa ...'upstairs siren' ('Fortrezz Siren') - Type: RelayDevice - Subtype: Siren Alexa ...'outlet' - Type: RelayDevice - Subtype: Outlet Alexa ...'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa ...'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa ...'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa ...'automatic door' - Type: RelayDevice - Subtype: Door Controller Alexa ...'Office Siren' - Type: RelayDevice - Subtype: Siren Alexa ...'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa ...'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa ...'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'office bulb' ('Hue Bulb') - Type: RelayDevice - Subtype: Plug-In Alexa ...'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa ...'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa ...'outside lights' ('Outdoor Appliance Module (45604)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve Alexa Found 17 devices to publish, replying
Remove All
button at the bottom. Note, if you are using other smart home skills, using that button will also cause those devices to be forgotten, so when you do a discover later you'll need to perform any steps needed to make discover work on for that skill.Plugins→Alexa→Show Device Publications
menu item and it will print the list of publications in the Event Log window.This should make all of your devices available in Alexa. Whenever you ask an Alexa device to discover, you will see the following Event Log line followed by a summary of publications:
menu item. Verify that you are saying the name that is published to Alexa if it's different than the name of the device in Indigo.Some steps to try when Alexa has a problem speaking the value of a variable:
