Reflectors provide:
Indigo→Start Local Server…
menu item.Allow remote access
checkbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.Enable secure internet access via Indigo Reflector
checkbox.Activate Reflector
button.A browser page will open to the http://www.indigodomo.com/account/codes/ page listing your registration codes.
Sign up
link below the login form. When you create an account, we'll send you an activation email that contains a link to activate your account. When you click that link, it will switch you back to your browser and open the reflectors page. If for some reason it doesn't, switch back to Indigo and click the Activate Reflector
button again and it will.Once on the registration codes list page, you'll see a message to click the Create Reflector link next to your Indigo registration code. Click on that link and you'll switch to the Reflectors page with a form field to enter your reflector name. When you submit that we will create the reflector, activate it, and take you back to the codes page which will show your reflector activated.
Lastly, switch back to the Indigo Start Local Server…
dialog. It should now show that the reflector status is activated and will show a link to your new reflector URL. Press the Start Server
button and that is it – Indigo will restart and automatically connect to your reflector! To access from the web, simply go to https://YOUR-REFLECTOR-NAME.indigodomo.net/
Indigo 2021.2→Stop Server
) but don't quit the Indigo ClientReset
link beside your reflector's status (it should say Activated before your press Reset)Start Local Server
button
You should now see an Activate Reflector
button towards the bottom of the dialog. Click that, log in to your reflector account, and select the appropriate reflector. If the reflector you want to use doesn't show in the list of inactive reflectors, contact us with the name of the reflector you're trying to activate and what steps you've performed.
link beside your reflector's status (it should say Activated before your press Reset). If the reflector has already been deactivated that is fine – just skip this step.Go→Go to Folder…
/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/
PrismReflector
Start Local Server
button
Indigo Touch for iOS is transparently integrated with the Indigo Reflector service. When you use your iOS device (iPhone, iPad, etc.) to connect to Indigo while in your house (and on your local Wi-Fi network), Indigo Touch will automatically retrieve and remember your reflector address. You can press the settings (gear) icon on the top toolbar then find the Reflector
item near the bottom to verify that it is working correctly.
Refreshing Image
control type then use a longer refresh duration (30 minutes or longer) for the image, especially if you plan to frequently access the page remotely.Note these usage suggestions only apply to connections when a reflector is being used. If you are directly connected to your Indigo Server on your home network or not using a reflector then the bandwidth isn't going through our servers and you can have Control Page images refreshed as frequently as you would like.
