apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
License Status Enumeration
Value Description
ActiveSubscription license has an active Indigo Up-to-Date subscription (access to a reflector)
Calculate Sunrise
Calculate Sunset
Event Log List
showTimeStamp No boolean indicate whether every line should have it’s timestamp prepended to the log entry - the default is true
Get Database File Name
Get Database File Path
Get Install Folder Path
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
Get Plugin
Get Plugin List
Get Reflector URL
Get Serial Ports
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Get Web Server URL
  1. Reflector (https://reflector.indigodomo.net) if a reflector is configured.
  2. Bonjour name (http://MacName.local:PORT) if it can be determined.
  3. Localhost (http://localhost:PORT) if all else fails.
No Parameters
Log
Remove All Delayed Actions
Send Email
Speak
indigo_2021.2_documentation/server_commands.txt · Last modified: 2021/12/01 17:12 by jay
