Variables
sharedProps | dictionary | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use var.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Class Method
The Variable class has a special method, getValue(TYPE, default=VALUE)
, that you can call which will retrieve the variable value as the specified Python class. There are a couple of advantages to using this method: first, it won't throw an exception but will always return a value; second, the Indigo server will do the conversion in the exact same way that it does type conversions when using variables in triggers and conditions. You can also optionally specify a default value if the value can't be successfully converted into the specified type. Here's a list of the valid types you can specify and what the default is if not specified:
Type Literal | Type Returned | Default |
bool | Boolean | True will be returned if the value is one of these: “true”, “on”, “yes”, and “1”. False will be returned if the value is one of these: “false”, “off”, “no”, and “0”. If no default value is specified and the value can't be successfully converted, the method will return False. |
int | Integer | An integer object will be returned if the value is an integer number or a float/decimal. In the latter case, the number will be rounded to the nearest integer. If no default value is specified and the value can't be converted, the method will return 0 |
float | Float | A float object will be returned if the value is a float/decimal or an integer. If no default value is specified and the value can't be converted, the method will return 0.0 |
Remember that accessing the value
property of a variable object (var.value
) will return a unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
Command Syntax Examples |
Parameters |
Delete the specified folder.
indigo.variable.delete(123)
Parameters |
direct parameter | Yes | integer | id or instance of the variable to delete |
Parameters |
direct parameter | Yes | integer | id or instance of the variable to duplicate |
Parameters |
direct parameter | Yes | integer | id or instance of the variable to get the dependencies for. |
ID : 552463741 (integer)
ID : 296710860 (integer)
Parameters |
direct parameter | Yes | integer | id or instance of the variable |
Parameters |
Update Value
Parameters |
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
