Indigo Object Model Reference
# some code here
# that does something
TermMeaning
For Scripters and Developers:
For Developers:
ClassCommand namespaceNotes
Schedule
Triggers
DeviceStateChangeTrigger (indigo.DeviceStateChangeTriggerindigo.devStateChange.*manipulate a device state change trigger
Variables
Protocol Specific Commands
General Commands
IOM Object Hierarchy Image
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Object Description
Object Events
Objects that support subscribeTochanges()
Lower-level Events
Low Level Commands (Insteon and x10 Only)
indigo.x10.subscribeToIncoming()
indigo.x10.subscribeToOutgoing()
        if cmd.cmdType == "sec":    # or "x10" for power line commands
            if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Filter Description
indigo.x10include X10 devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
Name Base Description
FileNotFoundErrorException This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use.
JSONDateEncoderJSONEncoder Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.JSONDateEncoder))
Return Static File
status No int the HTTP status code to return, defaults to 200
path_is_relative No boolean is the path a full path or relative to the plugin, defaults to True
content_type No string a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified
    "status": 404,
    "headers": {
        "Content-Type": "text/html"
    "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("[email protected]")
  • /www/perceptive/wiki/data/pages/indigo_2022.1_documentation/object_model_reference.txt
