Indigo Scripting Tutorial
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
    isOn = lamp.onState
from datetime import datetime
Access a custom device state
# get the device
# show all the device states:
print(dev.states)
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import requests
my_unicode_string = "éçø"
my_integer = 1
my_float = 1.0
import json
my_new_dictionary["my_list"]
class myCustomClass:
    def __init__(self):
        self.a=1
        self.b=2
    def __str__(self):
        return outputString
cl = myCustomClass()
Get the current server time:
indigo.server.getTime()
import datetime
import logging
print(logList)
except ValueError as e:
        myFolder = None
if lamp.folderId != 0:
    lampsFolder = None
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Plugin Host Prompt Image
indigo-host -e '
indigo_attachments.py
    import indigo
except ImportError:
    raise ImportError
def log(message, label=None):
import indigo_attachments
    raise ImportError
ImportError
Method Description
executeAction(actionId, deviceId, props)
This is the method that actually executes the action. actionId is the unique action id. deviceId is the id of the device that the action on which the action will perform (if it requires a device). props is a dictionary of properties that the action needs to process correctly. See the plugin's documentation for a description of what you need to pass in to execute actions.
restart(waitUntilDone=True)
This method will restart the plugin if it's already running. Pass the optional parameter waitUntilDone=False if you don't want to block while the plugin restarts (waitUntilDone defaults to True if it's no parameters are passed). If you're a plugin developer and you want to restart the plugin from within itself you should pass that parameter.
restartAndDebug(waitUntilDone=True)
The same as above, but it will restart in the debugger the user has selected in the Preferences.
Restart a Plugin
if airfoil_plugin():
    airfoil_plugin.restart()
  • /www/perceptive/wiki/data/pages/indigo_2022.1_documentation/plugin_scripting_tutorial.txt
