Airfoil Pro
Adding an Instance
Add Airfoil Instance Image
Airfoil Edit Group Image
Airfoil instances are actually a group of devices: the instance itself (the first tab), and then multiple speaker devices, one for each speaker device that your instance knows about. We set the name of the Airfoil Instance to the Airfoil name. For each speaker, we name the speaker with this pattern: “Speaker Name (Airfoil Instance Name speaker)” to help you see how the devices relate to each other. We also add a note to each speaker device with a bit more detail about its relationship to its parent Airfoil Instance device.
Airfoil Triggers Image
States available to Scripts
Notes
Each Airfoil Instance device has a collection of “Speaker” devices in its group. These are all the various outputs to which Airfoil can direct its source audio. These devices are created automatically when you create your Airfoil Instance and any time a new source gets added to the instance. For instance, if you create an Airfoil Instance and it finds 3 speakers, then at a later time you add a bluetooth speaker to the Mac that Airfoil is running on, the plugin will automatically create a new speaker device for that bluetooth speaker.
volume number If the source is iTunes and you've selected an iTunes server as the source in this device's config, this will mirror that device's playState
Action Menu Image
Connect Speaker
Scripting details
Action id: connect
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
        result = airfoilPlugin.executeAction("connect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
    except Exception, e:
        print "Exception occurred: %s" % unicode(e)
Disconnect Speaker
Scripting details
Action id: disconnect
        result = airfoilPlugin.executeAction("disconnect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Toggle Speaker
Scripting details
Action id: toggle
        result = airfoilPlugin.executeAction("toggle", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Save Current Speaker States
Scripting details
Example 1 (no groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Example 2 (include groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, props={"includeAirfoilGroups": True}, waitUntilDone=True)
Restore Saved Speaker States
Scripting details
        result = airfoilPlugin.executeAction("restoreSavedSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Set Volume
Scripting details
Action id: setVolume
        result = airfoilPlugin.executeAction('setVolume', deviceId=135305663, props={'volume': 50}, waitUntilDone=True)  # ID of Speaker device
Increase Volume
Scripting details
Action id: increaseVolume
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Example 2 (specifying delta):
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Decrease Volume
Scripting details
Action id: decreaseVolume
        result = airfoilPlugin.executeAction('decreaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Disconnect All Speakers
Scripting details
        result = airfoilPlugin.executeAction('disconnectAllSpeakers', deviceId=12345678, waitUntilDone=True)  # ID of Airfoil device
Change Source
Scripting details
Action id: changeSource
        props = {"sourceGroup": "systemAudio", "source": "com.rogueamoeba.source.systemaudio"}
        result = airfoilPlugin.executeAction("changeSource", deviceId=1346588091, props=props, waitUntilDone=True)
Save Current Source
Scripting details
Action id: saveCurrentSource
        result = airfoilPlugin.executeAction("saveCurrentSource", deviceId=1346588091, waitUntilDone=True)
Restore Saved Source
Scripting details
Action id: restoreSavedSource
        result = airfoilPlugin.executeAction("restoreSavedSource", deviceId=1346588091, waitUntilDone=True)
Toggle Play/Pause
Scripting details
Action id: playPause
        result = airfoilPlugin.executeAction('playPause', deviceId=12345678, waitUntilDone=True)
Next Track
Scripting details
Action id: nextTrack
        result = airfoilPlugin.executeAction('nextTrack', deviceId=12345678, waitUntilDone=True)
Previous Track
Scripting details
Action id: prevTrack
        result = airfoilPlugin.executeAction('prevTrack', deviceId=12345678, waitUntilDone=True)
getSources
Action id: getSources
        result = airfoilPlugin.executeAction('showSources', deviceId=12345678)  # deviceId is the Indigo ID of the Airfoil device
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
  • /www/perceptive/wiki/data/pages/indigo_2022.1_documentation/plugins/airfoilpro.txt
