Alexa
  1. Open the Alexa App.
  4. Tap the Search icon.
  5. Search for “Indigo Smart Home”. You should see a skill named Indigo Smart Home Skill in English speaking regions and Indigo Smart Home everywhere else, with an icon that matches the logo of the Mac Client.
  6. Add the skill.
Alexa Type Popup Image
  • Thermostats
On/Off Devices
  • Alexa, turn on office lamp
  • Alexa, turn off bedroom fan
  • Alexa, open garage door
Alexa Relay Subtypes Image
The options are:
    • Alexa, open the front door
    • Alexa, open the garage door
    • Alexa, lock the back door
    • Alexa turn off desk lamp
Dimmer Devices
warm, warm white 2200
incandescent, soft white 2700
white 4000
daylight, daylight white 5500
cool, cool white 7000
Alexa Dimmer Subtypes Image
The options are:
    • Alexa, close the shades
    • Alexa, ceiling fan speed
    • Alexa, turn off ceiling fan
    • Alexa, turn off the valve
Indigo Fan Devices
  • Alexa, increase ceiling fan speed
Indigo Thermostat Devices
  • Alexa, set the thermostat to cool
  • Alexa, what is my thermostat set to
  • Alexa, turn off the heat (Warning: this will turn the thermostat off regardless of mode)
  • Alexa, set the AC to seventy-five
  • Alexa, make it warmer in here
  • US, UK - “indigo” is the invocation
  • CA, AU - “indigo home” is the invocation
  • Alexa, ask Indigo to get “current_weather_conditions”
  • Alexa, ask Indigo to look up “current_weather_conditions”
  • Alexa, ask Indigo to read “current_weather_conditions”
  • Alexa, ask Indigo to say “current_weather_conditions”
  • Alexa, ask Indigo to speak “current_weather_conditions”
  • Alexa, ask Indigo to tell me “the_status_of_the_house”
  • Alexa, ask Indigo for the value of variable “current_weather_conditions”
  • Alexa, ask Indigo the value of “current_weather_conditions”
  • Alexa, ask Indigo the current value of “weather_conditions”
Get a List of Variables
Execute an Action Group
  • Alexa, tell Indigo to arm “the kitchen zone”
  • Alexa, tell Indigo to do “my favorite thing”
  • Alexa, tell Indigo to execute “toggle music”
  • Alexa, tell Indigo to launch “rocket”
  • Alexa, tell Indigo to make “the house secure”
  • Alexa, tell Indigo to perform “routine maintenance”
  • Alexa, tell Indigo to play “my favorite playlist”
  • Alexa, tell Indigo to reset “the alarm”
  • Alexa, tell Indigo to restart “the laundry timer”
  • Alexa, tell Indigo to restore “the standard speaker set”
  • Alexa, tell Indigo to run “routine maintenance”
  • Alexa, tell Indigo to start “the laundry timer”
  • Alexa, tell Indigo to set “the playlist to classic rock”
Plugin Startup
 Started plugin "Alexa 2022.1.0"
 Alexa                           Finding devices to publish to Alexa...
 Alexa                           ... '010 - Smart Fan Control (14287)' published as 'office fan'
 Alexa                           ... '016 - Plug-In Appliance Module (ZL-PA-100)' published as 'office lamp'
 Alexa                           ... '038 - Lamp Module (AD130)' published as 'blinds'
 Alexa                           ... 'automatic door' published
 Alexa                           ... 'FanLinc - Fan' published as 'ceiling fan'
 Alexa                           ... 'FanLinc - Light' published as 'fan light'
 Alexa                           ... 'Fortrezz Strobe' published as 'strobe'
 Alexa                           ... 'Hue Bulb' published as 'office bulb'
 Alexa                           ... 'Insteon Dimmer' published as 'valve'
 Alexa                           ... 'Insteon On/Off' published as 'back door'
 Alexa                           ... 'Insteon Thermostat' published as 'thermostat'
 Alexa                           ... 'Kasa Plug' published as 'garage door'
 Alexa                           ... 'Office Siren' published
 Alexa                           ... 'outlet' published
 Alexa                           ... 'Simple Virtual On/Off' published as 'simple switch'
 Alexa                           A total of 15 devices are currently published to Alexa
 Alexa Warning                   If you can't control a device, rerun discover from your Alexa device.
Showing Publications
 Alexa                           Currently published devices (Alexa name first if different than Indigo name):
 Alexa                             'Office Siren' ('Office Siren') - Type: RelayDevice - Subtype: Siren
 Alexa                             'automatic door' ('automatic door') - Type: RelayDevice - Subtype: Door Controller
 Alexa                             'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock
 Alexa                             'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind
 Alexa                             'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None
 Alexa                             'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer
 Alexa                             'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller
 Alexa                             'office bulb' ('Hue Bulb') - Type: DimmerDevice - Subtype: Color Bulb
 Alexa                             'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan
 Alexa                             'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In
 Alexa                             'outlet' ('outlet') - Type: RelayDevice - Subtype: Outlet
 Alexa                             'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch
 Alexa                             'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In
 Alexa                             'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None
 Alexa                             'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Discovery Requests from Alexa
 Alexa                           Alexa discovery request received, assembling reply...
 Alexa                           ...'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None
 Alexa                           ...'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch
 Alexa                           ...'upstairs siren' ('Fortrezz Siren') - Type: RelayDevice - Subtype: Siren
 Alexa                           ...'outlet' - Type: RelayDevice - Subtype: Outlet
 Alexa                           ...'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer
 Alexa                           ...'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan
 Alexa                           ...'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock
 Alexa                           ...'automatic door' - Type: RelayDevice - Subtype: Door Controller
 Alexa                           ...'Office Siren' - Type: RelayDevice - Subtype: Siren
 Alexa                           ...'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None
 Alexa                           ...'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind
 Alexa                           ...'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In
 Alexa                           ...'office bulb' ('Hue Bulb') - Type: RelayDevice - Subtype: Plug-In
 Alexa                           ...'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In
 Alexa                           ...'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller
 Alexa                           ...'outside lights' ('Outdoor Appliance Module (45604)') - Type: RelayDevice - Subtype: Plug-In
 Alexa                           ...'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
 Alexa                           Found 17 devices to publish, replying
Command Requests from Alexa
 Alexa                           turning on 'Hue Bulb'
 Sent Hue Lights                 "Hue Bulb" on to 100 at ramp rate 2.0 sec.
Full Switch
  4. Once you have all your devices published, you can confirm that they are all published by selecting the Plugins→Alexa→Show Device Publications menu item and it will print the list of publications in the Event Log window.
  5. In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say “discover devices”.
Partial Switch
  4. In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say “discover devices”.
Changing the Indigo Name
Changing the Device Type
  3. Save any changes.
  4. Rerun discovery in Alexa.
  1. Ensure that your Indigo Reflector is configured and connected. Check this by hitting your reflector URL in a browser: https://YOURREFLECTORNAME.indigodomo.net/
Alexa can't find a device
Alexa can't control a device
  2. Make sure you have the device published in the plugin. You can do this by selecting the Plugins→Alexa→Show Device Publications menu item. Verify that you are saying the name that is published to Alexa if it's different than the name of the device in Indigo.
  1. Make sure that the value doesn't contain any SSML markup symbols by themselves, like <, >, /, etc. Alexa will just throw a very unhelpful error (“Sorry, I'm having trouble accessing your Indigo Skills skill right now”) when it thinks that the string contains malformed SSML.
  1. If you have too many variables, you may get the error “There is a problem with the requested skill response”. The issue is that the speech output sent to Alexa can't be longer than 8000 characters, so if you have a lot of variables or lots of variables with long names you may run into this situation. The next release of the plugin will only speak variables that have the “Remote Display” flag set for them, so you will be able to exclude variables using that mechanism without deleting them.
If the value of your variable contains an ampersand (&) or perhaps other special characters, you should replace them with the actual english word (and). Alternately, you can probably HTML encode the character as well (&amp;).
If All Else Fails
  • /www/perceptive/wiki/data/pages/indigo_2022.1_documentation/plugins/alexa.txt
