NOAA Weather
NOAA Trigger States Image
  • Latitude - Latitude
  • Longitude - Longitude
  • Observation Date/Time - The last time NOAA updated the data. This field is in YYYY-MM-DD HH:MM:SS so it can be parsed by other software if needed.
  • Quality Codes - For scripters to account for the relative quality of the various weather observations (JSON). This state is only available in Indigo 2022.1 and later. See below for what the codes mean.
  • Time Zone - The timezone as it applies to the observed location. This state is only available in Indigo 2022.1 and later.
MADIS QC Information - Surface QC Data Descriptor Values
No QC available
Z Preliminary, no QC
Automated QC checks
C Coarse pass, passed level 1
S Screened, passed levels 1 and 2
V Verified, passed levels 1, 2, and 3 (BEST)
X Rejected/erroneous, failed level 1
Q Questioned, passed level 1, failed 2 or 3, where:
Quality Levels
level 1 = validity
level 2 = internal consistency, temporal consistency, statistical spatial consistency checks
level 3 = spatial consistency check
  import json
      indigo.server.log("trust")
  • /www/perceptive/wiki/data/pages/indigo_2022.1_documentation/plugins/noaaweather.txt
