sharedProps | dictionary | No | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use ag.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Command Syntax Examples |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to delete |
Display In Remote UI
Parameters |
direct parameter | No | integer | id or instance of the action group |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to duplicate |
duplicateName | No | string | name for the newly action group trigger |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to execute |
Parameters |
direct parameter | Yes | integer | id or instance of the action group |
