Deletion Dependencies
If you double-click on the dependency, the edit dialog for that object will open so you can change/remove it. If you want the dependent objects to be deleted, just click the Delete button.
indigo_2022.1_documentation/deletion_dependencies.txt · Last modified: 2022/03/11 20:28 (external edit)
