Indigo Web Server
Web Assets Folder Structure
Indigo 2022.1 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/images /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/plugins /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/static
As a convenience, you can access these folders under the Indigo Help menu: Help
–> Show Web Assets Folder
images folder
plugins folder
With Indigo 2022.1, web server plugins are no longer supported.
public folder
For example:
static folder
For example:
Authentication
Information on Indigo Authentication options can be found on the Restful URLS page under the authentication section.
Example
First, create your content. For example, web sites often contain a index.html
page. A simple index.html
page looks like this:
<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>Indigo Web Server</title> </head> <body style="height:100%; width:100%"> <div id="content" style="position:absolute; top:0px; left:0px; height:200px; right:0px;overflow:hidden;"> Hello world. </div> </body> </html>
Using a plain text editor, save this code as index.html
within the …/Web Assets/static
folder (to serve it with authentication) or within the …/Web Assets/public
folder (to serve it without authentication). You can refer to assets located in other folders by referencing them with the Web Assets
folder as the root.
