X10 Commands (indigo.x10.*)
 indigo.x10.sendAddress("A1")
direct parameter Yes string X10 address
suppressLogging No boolean
delta Yes integer the amount to brighten by relative to the current brightness - valid values from 1 to 100
suppressLogging No boolean a boolean indicating if entries in the event log should be suppressed (default is False)
updateStatesOnly No boolean use if you only want Indigo's internal device state representation to be updated - no actual X10 commands will be sent (default is False)
delta Yes integer the amount to dim by relative to the current brightness - valid values from 1 to 100
command Yes integer the comand to send
data Yes integer the data to send
indigo.x10.sendOn("A1")
indigo.x10.sendOff("A1")
  • /www/perceptive/wiki/data/pages/indigo_2022.2_documentation/x10_specific_commands.txt
