Command Syntax Examples |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to delete |
Display In Remote UI
Parameters |
direct parameter | No | integer | id or instance of the action group |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to duplicate |
duplicateName | No | string | name for the newly action group trigger |
Parameters |
direct parameter | Yes | integer | id or instance of the action group to execute |
Parameters |
direct parameter | Yes | integer | id or instance of the action group |
