Integration APIs
In Indigo v2022.2, we’ve completely redesigned the Indigo Web Server plugin (commonly referred to as IWS). The first major change is the new Indigo Touch for Web UI. We know you'll love this new UI (particularly given the old UI which was super dated):
This article, however, is about the two new APIs in IWS that developers can use to integrate Indigo with external services:
  • WebSocket API – (which the new Indigo Touch Web UI uses, and
Both of these APIs are authenticated with HTTP Digest and API Keys (either as a query string or preferably an Authorization header) depending on how the user configures it in the Start Local Server dialog.
NOTE:
  • We’re deprecating HTTP Basic authentication due to its insecure nature.
  • The old REST API has been deprecated in favor of the new HTTP API.
Versioning
A quick note on versioning: moving forward, all APIs will be versioned under the following scheme:
  • /v2/ - this is the top level version number and will change as necessary
Python vs JavaScript
  "key1": "value 1",
  "key2": 2
PythonJSON Equivalent
True true
False false
float Number
int Number
None null
dict Object
list Array
tuple Array
str String
WebSocket API
  • /v2/api/ws/device-feed - WebSocket to do all communication about devices
  • /v2/api/ws/variable-feed - WebSocket to do all communication about variables
  • /v2/api/ws/action-feed - WebSocket to do all communication about action groups
  • /v2/api/ws/page-feed - WebSocket to do all communication about control pages
  • /v2/api/ws/log-feed - WebSocket to do all communication about logs
WebSocket Lifecycle
  1. Setup:
Authentication
WebSocket API requests must be authenticated using an API Key. You can manage API Keys in the Authorizations section of your Indigo Account. Using keys instead of your Indigo Server username/password has several advantages: you can, at any time, revoke an API key, and it will immediately cause anything using it to fail. This will not affect anything else using a your username/password or another API key, so your server protections against intrusions are much more granular. Also, if someone does manage to get your API Key, they can control devices, but they cannot modify your database (add/delete devices, etc) - that is reserved for Indigo clients using the username/password.
wss://your-reflector.indigodomo.net/v2/api/ws/device-feed?api-key=YOUR-API-KEY
Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Be sure not to share your API keys with anyone not authorized to use them — especially in posts to the Indigo user forums.
Python Example
import asyncio
import websockets
import json
API_KEY = 'API-KEY-HERE'
async def receiver():
            while True:
    except Exception as exc:
        print(f"Exception:\n{exc}")
asyncio.run(receiver())
JavaScript Example
const APIKEY = "API-KEY-HERE";
  console.log(message.data);
Device Feed
add device message
  "message": "add",
  objectDict": {
    "address": "3B.04.7A",
    "batteryLevel": null,
    "blueLevel": null,
    "brightness": 100,
    "buttonConfiguredCount": 0,
    "buttonGroupCount": 1,
    "configured": true,
    "defaultBrightness": 100,
    "deviceTypeId": "",
    "displayStateValRaw": 100,
    "displayStateValUi": "100",
    "enabled": true,
    "energyAccumBaseTime": null,
    "energyAccumTimeDelta": null,
    "energyAccumTotal": null,
    "energyCurLevel": null,
    "errorState": "",
    "folderId": 1552926800,
    "globalProps": {
      "emptyDict": {}
    "greenLevel": null,
    "id": 1508839119,
    "ledStates": [],
    "name": "Insteon Dimmer",
    "onBrightensToLast": false,
    "onState": true,
    "ownerProps": {},
    "pluginId": "",
    "pluginProps": {},
    "redLevel": null,
    "remoteDisplay": false,
    "sharedProps": {},
    "states": {
      "brightnessLevel": 100,
      "onOffState": true
    "subModel": "Plug-In",
    "subType": "Plug-In",
    "supportsAllOff": true,
    "supportsColor": false,
    "supportsOnState": true,
    "supportsRGB": false,
    "supportsWhite": false,
    "version": 67,
    "whiteLevel": null,
    "whiteLevel2": null,
    "whiteTemperature": null
update device message
  "message": "patch",
  "objectId": 1508839119,
  "patch": [
      "change",
      "brightness",
      [100, 0]
      "change",
      "displayStateImageSel",
      "change",
      "displayStateValRaw",
      [100,  0]
      "change",
      "displayStateValUi",
      ["100", "0"]
      "change",
      "lastChanged",
      "change",
      "lastSuccessfulComm",
      "change",
      "onState",
      [true, false]
      "change",
      "states.brightnessLevel",
      [100, 0]
      "change",
      "states.onOffState",
      [true, false]
delete device message
  "message": "delete",
  "objectId": 123456789
Device messages to the server
device refresh messages
  "id": "optional-user-generated-refresh-device-message",
  "message": "refresh",
  // Specify the object type
If you want the entire device list, simply omit the objectId key and the server will return the full list.
When you ask to refresh the entire list, you will receive the following message from the server:
  "id": "optional-user-generated-refresh-device-list-message", // Reserved for future use.
  "list": []
  "objectDict": {}
device command messages
  "objectId": 123456789,
Variable Feed
wss://yourreflector.indigodomo.net/v2/api/ws/variable-feed
  "class": "indigo.Variable",
  "description": "",
  "folderId": 0,
  "globalProps": {
  "id": 345633244,
  "name": "house_status",
  "pluginProps": {},
  "readOnly": false,
  "remoteDisplay": true,
  "sharedProps": {},
  "value": "home"
add variable message
  "message": "add",
update variable message
delete variable message
variable refresh messages
  "id": "optional-user-generated-id", // Reserved for future use.
variable command messages
updateValue
  "parameters": {
    "value": "Some string value"
Action Group Feed
wss://yourreflector.indigodomo.net/v2/api/ws/action-feed
  "description": "",
  "folderId": 532526508,
  "globalProps": {
      "speakDelayTime": "5",
  "id": 94914463,
  "name": "Movie Night",
  "pluginProps": {},
  "sharedProps": {
add action group message
  "message": "add",
update action group message
delete action group message
action group refresh messages
action group command messages
Control Page Feed
wss://yourreflector.indigodomo.net/v2/api/ws/page-feed
  "backgroundImage": "",
  "description": "",
  "folderId": 0,
  "globalProps": {},
  "hideTabBar": true,
  "id": 963336187,
  "name": "Weather Images",
  "pluginProps": {},
  "sharedProps": {}
add control page message
  "message": "add",
update control page message
delete control page message
Indigo Object Folders
  "id": 617272302,
  "class": "indigo.Folder",
  "name": "My Device Folder",
refresh folder server message
  "id": "optional-user-generated-id", // This is just a pass through from the refresh request
Log Feed
Use this feed to catch all log messages as they happen in the Indigo Server. See the Log Messages section below for a description of a log message object.
When you first open the log-feed WebSocket, you will receive the last 25 log messages from the server in reverse chronological order. After that, the messages come through the socket as they are generated (chronological order). It is up to you to combine them in a way that works for you.
wss://yourreflector.indigodomo.net/v2/api/ws/log-feed
  "message": "add",
  "objectDict": {
    "message": "Stopping plugin \"Web Server 2022.2.0\" (pid 1020)",
    "typeStr": "Application",
    "typeVal": 0
HTTP API
HTTP API Endpoints
  • /v2/api/indigo.devices - endpoint to get a list of devices
  • /v2/api/indigo.devices/123456789 - endpoint to get a specific device instance (See Device Objects below)
  • /v2/api/indigo.variables - endpoint to get a list of variables
  • /v2/api/indigo.variables/123456789 - endpoint to specific variable object (See Variable Objects below)
  • /v2/api/indigo.actionGroups - endpoint to get a list of action groups
  • /v2/api/indigo.actionGroups/123456789 - endpoint to get a specific action group (See Action Group Objects below)
  • /v2/api/command - endpoint to send Indigo a command (device control, variable update, action execution).
Authentication
https://your-reflector.indigodomo.net/v2/api/indigo.device/123456789?api-key=YOUR-API-KEY
When using HTTPS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be HTTP and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Be sure not to share your API keys with anyone not authorized to use them — especially in posts to the user forums.
Getting Device Objects
Getting All Device Objects
import json
REFLECTORNAME = "your-reflector-name"
APIKEY = "YOUR-API-KEY"
with urlopen(req) as request:
    print(device_list)
const REFLECTORNAME = "your-reflector-name"
const APIKEY = "YOUR-API-KEY"
const http = require("https")
const options = {
  headers: {
  let result = ""
    result += chunk;
  response.on("end", () => {
    console.log(deviceList);
curl -H "Authorization: Bearer YOUR-API-KEY" https://your-reflector-name.indigodomo.net/v2/api/indigo.devices
import json
DEVICEID = 123456789  # Indigo device id
    print(device_instance)
const DEVICEID = 123456789  // an Indigo device id
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(deviceInstance);
curl -H "Authorization: Bearer YOUR-API-KEY" https://your-reflector-name.indigodomo.net/v2/api/indigo.devices/123456789
Controlling an Indigo Device
import json
message = json.dumps({
    "objectId": DEVICEID
}).encode("utf8")
    reply = json.load(request)
    print(reply)
const options = {
  path: "/v2/api/command",
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.device.toggle", "objectId": 123456789}' https://your-reflector-name.indigodomo.net/v2/api/command
import json
  "objectId": DEVICEID,
  "parameters": {
    "value": 50,
    "delay": 10
}).encode("utf8")
    print(reply)
  "parameters": {
    "value": 50,
    "delay": 10
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.dimmer.setBrightness", "objectId": 123456789, "parameters": {"value": 50, "delay": 10}}' https://your-reflector-name.indigodomo.net/v2/api/command
Getting Variable Objects
Getting All Variable Objects
import json
    print(variable_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(VariableList);
curl -H "Authorization: Bearer YOUR-API-KEY" https://your-reflector-name.indigodomo.net/v2/api/indigo.variables
import json
    print(var_instance)
const VARID = 123456789  // an Indigo variable object id
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(varInstance);
curl -H "Authorization: Bearer YOUR-API-KEY" https://your-reflector-name.indigodomo.net/v2/api/indigo.variables/123456789
Updating a Variable's Value
import json
VARIABLEID = 123456789  # Indigo variable id
  "objectId": VARIABLEID,
  "parameters": {
}).encode("utf8")
    print(reply)
const VARIABLEID = 123456789  // an Indigo variable id
  "parameters": {
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.variable.updateValue", "objectId": 123456789, "parameters": {"value": "Some string value"}}' https://your-reflector-name.indigodomo.net/v2/api/command
Getting Action Group Objects
import json
    print(action_group_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(actionGroupList);
curl -H "Authorization: Bearer YOUR-API-KEY" https://your-reflector-name.indigodomo.net/v2/api/indigo.actionGroups
Executing an Action Group
import json
ACTIONGROUPID = 123456789  # Indigo action group id
  "objectId": ACTIONGROUPID
}).encode("utf8")
    print(reply)
const ACTIONGROUPID = 123456789  // an Indigo action group id
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message": "indigo.actionGroup.execute", "objectId": 123456789}' https://your-reflector-name.indigodomo.net/v2/api/command
API Messages
Device Messaging
Device Objects
Example device object
  "blueLevel": null,
  "brightness": 0,
  "configured": true,
  "deviceTypeId": "",
  "displayStateValRaw": 0,
  "displayStateValUi": "0",
  "enabled": true,
  "errorState": "",
  "folder": {
    "id": 1552926800,
    "name": "Insteon",
  "globalProps": {},
  "greenLevel": null,
  "id": 1508839119,
  "ledStates": [],
  "onState": false,
  "ownerProps": {},
  "pluginId": "",
  "pluginProps": {},
  "redLevel": null,
  "sharedProps": {},
  "states": {
    "brightnessLevel": 0,
    "onOffState": false
  "version": 67,
  "whiteLevel": null,
HTTP The folder element is only available in the HTTP API. Folders are handled differently in the WebSocket API.
The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
indigo.device
WebSocket This won't necessarily cause a device update message - if the device didn't have any changes after the status request, there will be no updates to the device in the server, so no update message will be sent out the websocket.
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "value": True,
indigo.dimmer
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "value": 50,
    "delay": 10
indigo.iodevice
  "parameters": {
    "index": 5,
    "value": true
indigo.sensor
  "parameters": {
    "value": true
indigo.speedcontrol
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "value": 2,
    "delay": 5
set speed level indigo.speedcontrol.setSpeedLevel(123456789, index=2, value=True)
  "parameters": {
    "value": 50,
    "delay": 5
indigo.sprinkler
  "parameters": {
    "schedule": [10,15,8, 0, 0, 0, 0, 0]
  "parameters": {
    "index": 2
indigo.thermostat
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "value": 76
  "parameters": {
  "parameters": {
    "value": 76
  "parameters": {
Variable Messaging
Variable Objects
  "description": "",
  "folderId": 0,
  "folder": {},
  "globalProps": {
  "id": 345633244,
  "pluginProps": {},
  "readOnly": false,
  "sharedProps": {},
  "value": "home"
The only action that can currently be performed on a variable is to update the value. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
  "parameters": {
Action Group Messaging
  "description": "",
  "folder": {
    "id": 532526508,
    "name": "Mood Scenes",
  "globalProps": {
  "id": 94914463,
  "pluginProps": {},
  "sharedProps": {
There is only a single action group command, and that's to execute it. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests.
Log Messages
Example Log Message
  "typeVal": 0
EVENT_TYPES = {
  Application = 0,
  Error = 1,
  Error_Client = 2,
  Warning = 3,
  Warning_Client = 4,
  Debug_Server = 5,
  Debug_Client = 6,
  Debug_Plugin = 7,
  Custom = 8,
Error Messaging
Generic Error Message
  "validationErrors": {
Example API Call
  "parameters": {
    "value": 1234.56
Resulting Error Message
  1. message,
  2. objectId,
  3. parameters, and
  4. value
Invalid JSON
Example Invalid JSON Message
  "error": "invalid JSON"
indigo_2022.2_documentation/api.txt · Last modified: 2023/03/24 19:40 by jay
