Python Packages and Indigo
This page describes how Indigo 2022.2.0 works with Python, specifically with respect to packages/libraries.
Indigo 2022.2 shipped with API version 3.0 and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 2 and Python 3 are now automatically installed as part of the Indigo installer. For Indigo 2022.2, we are including both Python 3.10.2 and Python 2.7.18 (for backwards compatibility - it is an x86 install and will require Rosetta to run on Apple Silicon Macs). The Python 2.7.18 install was specifically added because macOS 12.3 removed its Python install and is a transitional step only. Python 2 and support for APIs < 3.0 will be removed in Indigo 2022.2 later this year.
The Indigo 2022.2 installer includes the Python 2.7.18 installer (which is Intel only) and the Python 3.10.2 installer (includes Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums.
Installing Additional Python Packages with Indigo 2022.2
As noted above, Indigo 2022.2 ships with two versions of Python. Each version contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
We were able to extend support for Python 2 as a convenience for our users. As a result, Indigo 2022.2 will continue to support Python 2 and Python 3. Users should plan for Python 2 support to be dropped in Indigo 2023.1.
For plugins that use Python 3, use pip3 install [package] commands to install packages:
For plugins that use Python 2, use pip2 install [package] commands to install packages:
user@my mac ~ % pip2 install pytorch
user@my mac ~ % pip3 list
Package            Version
astroid            2.9.3
certifi            2021.10.8
charset-normalizer 2.0.11
cycler             0.11.0
fonttools          4.29.1
user@my mac ~ %
Version: 2.27.1
Author: Kenneth Reitz
License: Apache 2.0
Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
Required-by:
user@my mac ~ %
Installing additional Python versions on the Indigo 2022.2 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
The PYTHONPATH for IPH3 is:
  1. Server Plugin
  2. IndigoPluginHost3
  3. /Library/Application Support/Perceptive Automation/Python3-includes
  4. /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
and the PYTHONPATH for IPH2 is:
  1. Server Plugin
  2. IndigoPluginHost
  3. /Library/Application Support/Perceptive Automation/Python2-includes
  4. /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Packages are installed in three ways:
  1. Some packages are included within the IPH itself. These are “protected” and can not be modified (listed below).
  2. You may add modules/packages that you develop yourself to the Python#-includes folders above, and those will be shared across all Indigo Plugins and Scripts.
  3. Other packages are installed using a pip3 (or pip2) process. Warning: Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
Access to IPH3 Libraries
Method Access to
IPH3 Libraries
plugins yes
embedded scripts yes
linked scripts yes
Python Packages for Scripters
  1. IndigoPluginHost3
  3. /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
  • /Library/Application Support/Perceptive Automation/Scripts – any linked scripts you use for Indigo Schedules and Actions using the “Execute Script (Script and File Actions” command should be stored in this folder.
  • /Library/Application Support/Perceptive Automation/Python3-includes – any modules you have developed (a module is a file that contains classes, functions, constants, etc.) that you want to share across multiple scripts, should be stored in the /Library/Application Support/Perceptive Automation/Python3-includes folder. (Indigo versions prior to 2022 should use the /Library/Application Support/Perceptive Automation/Python2-includes folder).
If Something Goes Wrong
To provide users with a measure of safety regarding the Python packages that Indigo installs, the Indigo installer also includes the capacity to repair the Python installation if something should become damaged. For example, if a user were to accidentally upgrade one of the Python packages – and as a result cause the Indigo server to stop functioning properly – re-running the Indigo installer may be able to bring things back under control.
Indigo 2022.2 ships with the following Python 3 packages in addition to the packages installed with the standard Python framework.
Included inside IPH 3
Unmodifiable
PIP installed by Indigo
PIP Modifiable (but not recommended)
Python Package Version Python Package Version
py-applescript 1.0.3 cycler 0.11.0
certifi 021.10.08 dictdiffer 0.9.0
charset_normalizer 2.0.12 fonttools 4.31.2
python-dateutil 2.8.2 future 0.18.2
idna 3.3 janus 1.0.0
jedi 0.18.1 - typing_extensions 4.4.0
oauthlib 3.2.0 Jinja2 3.1.2
packaging 21.3 kiwisolver 1.4.0
parso 0.8.3 MarkupSafe 2.1.1
pudb 2022.1.0 matplotlib 3.5.1
pyaes 1.3.0 numpy 1.22.3
pygments 2.11.2 packaging 21.3
pyparsing 3.0.7 Pillow 9.0.1
pyserial 3.5 pyparsing 3.0.7
requests 2.27.1 python-dateutil 2.8.2
requests-oauthlib 1.3.1 sanic 22.6.1
urllib3 1.26.8 - aiofiles 22.1.0
urwid 2.1.2 - httptools 0.5.0
xmljson 0.2.1 - multidict 6.0.4
- sanic-routing 22.3.0
- sanic-session 0.8.0
- ujson 5.7.0
- uvloop 0.17.0
- websockets 10.4
scipy 1.8.0
six 1.16.0
Python 2.7.18 Packages Installed by Indigo
Indigo 2022.1 ships with the following Python 2 packages in addition to the packages installed with the standard Python framework.
Included inside IPH 2
Unmodifiable
enum 1.1.6 backports.functools-lru-cache 1.6.4
oauthlib 2.0.2 cycler 0.10.0
requests 2.10.0 future 0.18.2
requests-oauthlib 0.8.0 kiwisolver 1.1.0
pudb 2016.1 matplotlib 2.2.5
py-applescript 1.0.3 numpy 1.16.6
pyaes 1.3.0 pyparsing 2.4.7
pygments 2.1.3 python-dateutil 2.8.2
pyserial 3.1.1 pytz 2022.1
python-dateutil 2.8.2 scipy 1.2.3
six 1.16.0 six 1.16.0
urwid 1.3.1 subprocess32 3.5.4
xmljson 0.1.7
indigo_2022.2_documentation/python_packages.txt · Last modified: 2023/02/24 02:13 by davel17
