Indigo Web Server
Web Server Settings Image
Beginning with Indigo 2023.1, an Advanced Web Server Settings… menu item was added to the Indigo menu. The menu has three options:
Indigo 2023.1 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/images
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/plugins
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/public
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/static
images folder
plugins folder
public folder
For example:
static folder
For example:
Authentication
API Keys
Local Secrets
In addition to authentication via API Keys and the Indigo Reflector (recommended), users can create their own local secrets (another type of key) that don't require an internet connection to validate. Users can create a JSON list of their own “secrets” that will be loaded whenever the web server is restarted. The secrets file is located in the install folder's /Preferences directory and is named secrets.json. This feature was introduced with Indigo version 2023.1:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Preferences/secrets.json
    "here-is-a-key",
    "this*is*another*key"
    "here-is-a-key",
    "this*is*another*key",
    "do-not-use-api-keys"
Custom Web Page Example
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
  </head>
      Hello world.
    </div>
  </body>
</html>
  • /www/perceptive/wiki/data/pages/indigo_2023.1_documentation/indigo_web_server.txt
