Python Packages and Indigo
This page describes how Indigo 2023.1.0 works with Python, specifically with respect to packages/libraries.
Indigo 2023.1 shipped with API version 3.3 (API 3.3 involved internal changes – most developers should use API 3.2) and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 2 and Python 3 are now automatically installed as part of the Indigo installer. For Indigo 2023.1, we are including both Python 3.10.2 and Python 2.7.18 (for backwards compatibility - it is an x86 install and will require Rosetta to run on Apple Silicon Macs). The Python 2.7.18 install was specifically added because macOS 12.3 removed its Python install and is a transitional step only. Python 2 and support for APIs < 3.0 will be removed in Indigo 2023.1 later this year.
The Indigo 2023.1 installer includes the Python 3.10.2 installer (includes Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums. Indigo 2023.1 no longer includes the Python 2.7.18 installer but it will not remove any previously installed Python 2.
Installing Additional Python Packages with Indigo 2023.1
As noted above, Indigo 2023.1 ships with Python 3.10 and which contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
Last login: Sun Mar 27 10:20:04 on ttys000 user@my mac ~ % pip3 show requests Name: requests Version: 2.27.1 Summary: Python HTTP for Humans. Home-page: https://requests.readthedocs.io Author: Kenneth Reitz Author-email: [email protected] License: Apache 2.0 Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages Requires: charset-normalizer, certifi, idna, urllib3 Required-by: user@my mac ~ %
Installing additional Python versions on the Indigo 2023.1 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
The PYTHONPATH for IPH3 is:
/Library/Application Support/Perceptive Automation/Python3-includes/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
- Some packages are included within the IPH itself. These are “protected” and can not be modified (listed below).
pip3process. Warning: Indigo will preinstall several packages (listed below) at install time. You should avoid modifying those unless absolutely necessary as other 3rd party plugins may rely on them.
Standard Installation
If your users will need to install multiple packages, it may be easier to specify those in a “requirements.txt” file within your plugin bundle. The following pip command will attempt to install all the packages listed in the file.
pip3 install -r requirements.txt -t /Path/To/Plugin/Contents/Packages/
Access to IPH3 Libraries
| plugins | yes |
| embedded scripts | yes |
| linked scripts | yes |
Python Packages for Scripters
- IndigoPluginHost3
- /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
- /Library/Application Support/Perceptive Automation/Scripts – any linked scripts you use for Indigo Schedules and Actions using the “Execute Script (Script and File Actions” command should be stored in this folder.
If Something Goes Wrong
Indigo 2023.1 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below.
| Included inside IPH 3 Unmodifiable | PIP installed by Indigo PIP Modifiable (but not recommended) |
| Python Package | Version | Python Package | Version |
| py-applescript | 1.0.3 | cycler | 0.11.0 |
| certifi | 2021.10.8 | cryptography | 41.0.1 |
| charset_normalizer | 2.0.12 | - cffi | 1.15.1 |
| python-dateutil | 2.8.2 | - pycparser | 2.21 |
| idna | 3.3 | dictdiffer | 0.9.0 |
| jedi | 0.18.1 | fonttools | 4.31.2 |
| oauthlib | 3.2.0 | future | 0.18.2 |
| packaging | 21.3 | httpx | 0.23.3 |
| parso | 0.8.3 | - anyio | 3.6.2 |
| pudb | 2022.1.0 | - certifi | 2022.12.7 |
| pyaes | 1.3.0 | - h11 | 0.14.0 |
| pygments | 2.11.2 | - httpcore | 0.16.3 |
| pyparsing | 3.0.7 | - idna | 3.4 |
| pyserial | 3.5 | - rfc3986 | 1.5.0 |
| requests | 2.27.1 | - sniffio | 1.3.0 |
| requests-oauthlib | 1.3.1 | janus | 1.0.0 |
| urllib3 | 1.26.8 | - typing_extensions | 4.4.0 |
| urwid | 2.1.2 | Jinja2 | 3.1.2 |
| xmljson | 0.2.1 | kiwisolver | 1.4.0 |
| MarkupSafe | 2.1.1 | ||
| matplotlib | 3.5.1 | ||
| numpy | 1.22.3 | ||
| packaging | 21.3 | ||
| Pillow | 9.0.1 | ||
| pyparsing | 3.0.7 | ||
| python-dateutil | 2.8.2 | ||
| pyobjc | 8.4.1 | ||
| sanic | 22.6.1 | ||
| - aiofiles | 22.1.0 | ||
| - httptools | 0.5.0 | ||
| - multidict | 6.0.4 | ||
| - sanic-routing | 22.3.0 | ||
| - sanic-session | 0.8.0 | ||
| - ujson | 5.7.0 | ||
| - uvloop | 0.17.0 | ||
| - websockets | 10.4 | ||
| scipy | 1.8.0 | ||
| six | 1.16.0 | ||
