Indigo Web Server
Advanced Web Server Settings
In Indigo 2023.2, an Advanced Web Server Settings… menu item was added to the Indigo menu. The menu has three options:
- Debug Logging: Enable this setting to show extra Web Server debugging information.
- Hide Security Logging: Enable this setting to hide HTTP API connection attempts. Warning: enabling this will reduce the logging of incoming HTTP API requests. We recommend keeping these messages as they can help identify security issues.
- Cache Controls: If you are having issues with cached API Keys (not Local Secrets), use the button to clear the key cache. This will force Indigo to connect to your Indigo Account to validate the next transaction which contains an API Key.
Web Assets Folder Structure
Indigo 2023.2 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Web Assets/images /Library/Application Support/Perceptive Automation/Indigo 2023.2/Web Assets/plugins /Library/Application Support/Perceptive Automation/Indigo 2023.2/Web Assets/public /Library/Application Support/Perceptive Automation/Indigo 2023.2/Web Assets/static
images folder
plugins folder
public folder
For example:
static folder
For example:
Authentication
API Keys
Local Secrets
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Preferences/secrets.json
"here-is-a-key",
"this*is*another*key"
"here-is-a-key",
"this*is*another*key",
"do-not-use-api-keys"
Custom Web Page Example
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
</head>
Hello world.
</div>
</body>
</html>
