Indigo Server Plugin Tutorial
Note most of the code examples below are calling methods on the object self. In this context, self is meant to be the Plugin instance as defined inside the plugin.py file. To execute the sample code outside of Plugin instance methods, use the indigo.activePlugin object instead.
Important: For simplicity, some of the samples below specify objects based on name (indigo.devices[“office desk lamp”]). However, the preferred lookup mechanism is to use the object's numeric ID (indigo.devices[12345678]), which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the numeric ID you ensure the object will be found even if its name is changed.
Included in the SDK are examples that create plugin based relay, dimmer, thermostat, sensor, speed control, sprinkler, energy meter and custom devices. Also included is an example showing basic Indigo database traversal, how to catch low-level X10/INSTEON messages, and how to create an Indigo telnet server using the python twisted framework. The following table lists the Indigo Plugin SDK examples that were available at the time Indigo 2023.2 shipped.
| SDK Plugin task | Plugin that illustrates an approach |
| Broadcast Plugin Information to Listeners | Example Custom Broadcaster |
| Subscribe to Plugin Information Broadcast | Example Custom Subscriber |
| Walk Through the Indigo Database | Example Database Traverse |
| Non-native Device Type | Example Device - Custom |
| Energy Meter Device Type | Example Device - Energy Meter |
| Device Factory Device Type | Example Device - Factory |
| Switch / Relay / Dimmer Device Type | Example Device - Relay and Dimmer |
| Sensor Device Type (Water, Motion, Light, Humidity) | Example Device - Sensor |
| Speed Control Device Type (Fan) | Example Device - Speed Control |
| Sprinkler Device Type | Example Device - Sprinkler |
| Thermostat Device Type | Example Device - Thermostat |
| Interact with the Indigo Server Using HTTP Client / Server | Example HTTP Responder |
| Listen for Insteon and/or X-10 Traffic | Example INSTEON:X10 Listener |
| Listen for Indigo Variable Change Notifications | Example Variable Change Subscriber |
| Listen for Z-Wave Traffic | Example ZWave Listener |
| Parsing JSON, XML from an IP source | NOAA Weather, WeatherSnoop |
| Integrating with native Mac Apps | Airfoil |
| Sending RS232 (serial port & network serial port) Commands | EasyDAQ |
| Reading RS232 (serial & network serial port) Input | EasyDAQ |
| Interacting with an IMAP mail server | Email+ |
| Interacting with an HTTP Web server | Example HTTP Responder |
| Creating custom devices with states | Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ |
| Creating custom actions | GhostXML |
| Creating custom events | Airfoil |
- The per plugin preferences (pref) file is automatically managed (created, loaded, updated).
- Key values defined in
PluginConfig.xmlare automatically mapped into the plugin's prefs space which is available via:
- Or, if you're not sure the key exists:
- The latter will return the second parameter if they key doesn't exist in the dictionary - it's your responsibility to add it to the prefs dict if you want it to be stored permanently.
- A plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin's config UI). This is a great way to maintain values that are not directly visible or available to the end user.
- To read a preference value access its key:
- To create a new or update an existing preference value assign it a new value:
- The Indigo server will save the plugin prefs automatically, but you can also cause them to be saved to the server immediately using:
indigo.server.savePluginPrefs
.pluginProps. - The pluginProps dictionary supports numbers, boolean, strings, indigo.Dict() or indigo.List().
dev = indigo.devices["den fixture"] # device ID preferred newProps = dev.pluginProps newProps["onCycles"] = 5 newProps["moreData1"] = "abc" newProps["moreData2"] = True newProps["moreData3"] = 123.45 dev.replacePluginPropsOnServer(newProps)
Read plugin specific property ''onCycles'' from the Device "den fixture"
newProps["onCycles"] += 1
- Plugins have read-only access to other plugin metadata via
.globalProps. - Plugins have read/write access to their own metadata space.
How to Create a Custom Plugin Device
- Properties define the user configurable options for a device instance, and are specified in the
<ConfigUI>XML node. Every fieldidis automatically mapped into the device instance.pluginPropsmetadata dictionary (described above) as a unique key. - States are specified in the Devices.xml
<States>XML node, and are used to define the transient state information for a device (ex: on/off setting, brightness, temperature, etc.). - States defined in Devices.xml are automatically shown in the Trigger Event
Device State Changedoptions when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device. - States are read-only for everyone except the plugin that defines the device's states.
- Plugins should update a device state after it has sent commands to hardware, or somehow received new state information from hardware. Example that increments the plugin defined state
heatSetPointby 1:
dev = indigo.devices["Custom Plugin Thermostat"] # device ID preferred
- Plugins should subclass
deviceStartCommanddeviceStopCommto start/stop any hardware communication (normally via a new per-device thread):
- Calls to
deviceStartCommanddeviceStopCommare automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receivedeviceStartCommcalls. Likewise,deviceStartCommis called when a new plugin device is created or duplicated.deviceStopCommis called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
How to Create a Custom Plugin Trigger Event
<?xml version="1.0"?>
<Events>
<Event id="updateAvailable">
<ConfigUI>
<SupportURL>https://www.yourdomain.com/plugin/someOtherEvent.html</SupportURL>
<Field id="someLabel" type="label">
<Label>This label contains some useful configuration instructions.</Label>
</Field>
</ConfigUI>
</Event>
</Events>
As you can see, your <Event> elements can define a <SupportURL> element as well – and separate support elements for the event's configuration dialog (the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL). You can specify an Event to be a separator in your event list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
There are several Event-related and Trigger-related methods that you can add to your plugin.py file–some of which are required in order to have the Event do something. These methods include:
| Element | Description |
| self.closedEventConfigUi(self, values_dict, user_cancelled, type_id, event_id) | Called after user clicks the Save button within the event configuration dialog (after 'validateEventConfigUi()' method has finished successfully). Used to finalize any Event configuration steps. |
| self.getEventConfigUiValues(self, plugin_props, type_id, event_id) | Called when an Event configuration window is first opened. |
| self.getEventConfigUiXml(self, type_id, event_id) | Called when an Event configuration window is first opened. The method is used to provide a valid XML payload in place of the Events.xml file. |
| validateEventConfigUi(self, values_dict, type_id, event_id) | Called when a user clicks the Save button within the event configuration dialog. Used to provide configuration input validation to ensure the settings are within your parameters. |
The power of Events
How to Monitor Changes to Various Indigo Objects
Indigo provides a method to do this by allowing the plugin to “subscribe” to changes for all objects in a particular class.
To monitor changes to different classes of Indigo objects, you can include a call to the appropriate subscribeToChanges method. Calling any of these methods tells Indigo to send a notification to the plugin of any changes to all objects of that type – not only plugin's own objects – so use these methods sparingly.
| Element |
| indigo.schedules.subscribeToChanges() |
| indigo.controlPages.subscribeToChanges() |
| Element |
| self.deviceCreated(self, dev) |
| self.deviceDeleted(self, dev) |
| self.deviceUpdated(self, orig_dev, new_dev) |
def deviceCreated(self, dev):
def deviceDeleted(self, dev):
orig_dict = {}
for (k, v) in orig_dev:
orig_dict[k] = v
new_dict = {}
for (k, v) in new_dev:
new_dict[k] = v
Monitor Changes to Variables
| Element |
| self.variableCreated(self, var) |
| self.variableDeleted(self, var) |
| self.variableUpdated(self, orig_var, new_var) |
